Synergy for the Propeller - Share your PC's mice and keyboard
I have proposed a little project and want to gauge interest.
This would allow you to use your main PC's mouse and keyboard to control your propeller microcontroller using the popular and open-source Synergy software.
Here's how it works: On your main desktop PC you run a Synergy server which shares your mouse/kbd with any number of Synergy clients. You normally run Synergy clients on other PCs, but for the propeller you instead run a special synergy client which acts like just another client PC, but is running on the server PC. It talks to the propeller over serial (or serial-over-USB). The propeller then decodes the communication and interfaces with software there via hacked keyboard/mice objects (which are drop-in replacements for the standard ones!). Note that the propeller doesn't need to speak TCP/IP or any nonsense like that, it just needs to accept simple serial packets from the hacked synergy client on the PC which does all the dirty work for it.
The great advantage here is, no need for a second mouse/keyboard on your desk for the propeller (if you are not using the serial port for anything else that is). It could be a great aid during development to be able to mouse-over to your propeller environment. You could even copy-paste between them with ease.
If there is any interest I will write the hacked synergy client and propeller objects, it should be pretty straight forward to do.
(i will maintain network transparency and portability if at all possible)
> Chris
> Chris
That sounds like a great idea! I use Synergy with my PC's now and it would be great to move the mouse across 2 PC's and onto the propeller VGA display. Definitely put me on the list of interested people
Cheers,
Shane
You might also like to check out prop terminal, it emulates the mouse, keyboard and TV display on your PC via the usb programming interface:
http://forums.parallax.com/showthread.php?p=649540
Definetly a E3 (Electronics Engineer Extrodinare!)
"I laugh in the face of imposible,... not because i know it all, ... but because I don't know well enough!"
Graham, thanks for the link to PropTerminal. It would make sense to use the same Propeller-side code.
I will keep you updated on any progress.
