Robotics Platform
I need some advice. I'm looking for a robotic base. I don't have a machine shop to build anything complex, so if possible I would like to purchase a kit or parts to build one. I've seen several ones that are running into the thousands and I don't have that kind of money. Most likely I will be running a propeller chip along with two HB motor controllers. I've thought about purchasing an iRobot create and attach a propeller to that, but I was kind of interested in something that could go off a flat surface. Ultimately a platform that could also support a light weight laptop (4 pounds) and GPS for navigation/location would be great. Can I build something like this on my own without spending a fortune? Slightly off topic, but I'm living in Mountain View, CA (Far away from the midwest) for the summer doing an internship and I was wondering if there are any GEEKY places I can't be sure to miss? I plan on going to the Computer history museum around the corner. Any places that have some good robotics?
Matt
Matt
-My 2 cents.
You might take a look at this link if you change your mind about the Create/Propellor combination: http://www.wulfden.org/create/wac1.shtml
Just a thought.
TCIII
If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
Post Edited (Tom C) : 6/18/2007 7:23:15 PM GMT
I have thought about the RC Truck kit in the past as well. They definitely would have the maneuverability that I'm looking for. I have seen people that have used R/C tanks, but they seemed to have problems themselves. What RC chassis are you using? A power wheels would be cool, but I don't really have the room to store it.
Kevin,
My problem with building my own, as much as I want to, is trying to match up gears with wheels and what not. I am not mechanically inclined I guess.
Matt
http://robotstore.com/store/product.asp?pid=782&catid=1552
Your link is to a Lynxmotion 4WD2 which you can buy directly from Lynxmotion: http://www.lynxmotion.com/Category.aspx?CategoryID=58
You might want to try the 4WD1, which I have, which is cheaper by about $40: http://www.lynxmotion.com/Category.aspx?CategoryID=57
Anything that you buy from Jim Frye at Lynxmotion is going to be a quality product.
TCIII
That it is. I kinda like the one I linked over the basic once because the two halves can swivle giving it somthing akin to suspension.
Hi,
I am using an RC tank platform which I hacked very easily. I have removed the RC receiver, I added an H-bridge from (http://geocities.com/jimforkin2003) which incidentally is excellent.
Now, am in the process of adding sensors for the turret rotation, gun position, obstacle avoidance, etc. If you want I could email you some preliminary pictures that I took.
I have had very little trouble thus far.
John
I've built sever bots out of plexi and Lexan. it's a really inexpensive medium. Most Plastics suppliers will cut pieces to order. even round and with holes.
this post talks about other building materials.
http://forums.parallax.com/forums/default.aspx?f=10&m=189280&g=189405#m189405
I think you'll be much happier building your own chassis, and putting more money into sensors.
Good luck
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
But even the cheap RC models have differentials on the rear, proper steering
(that is, the inner tire turns at a tighter angle), usually four-wheel independent
suspension, and plenty of speed. Most of all, though, the mechanicals are really
built to take a beating; a few of the cheap RC cars I've bought have been crashed
a *lot* (slamming directly into curbs at full speed) and they never seem to break.
On the other hand, they still look and function like R/C cars. For instance,
they won't pivot in place like most standard two-wheel robots will. They really
aren't designed for adding any significant additional weight. They frequently
do not have a convenient place to attach sensors or additional electronics.
And frequently they are *too* fast, and hard to throttle down (even the
digital proportional models need some sort of sensors to monitor the speed;
just varying the pulse widths may give you a stall on some terrain while
giving you substantial speed on other terrain.)
A lot depends on what you are good at. I stink at the mechanicals, really really
have no talent there, but I can program, so I like kits and slightly modified
R/C cars that I can just attach a microcontroller and sensors to. But the
amazing robots people build from "scratch" always impress me.
http://stores.ebay.com/8020-Inc-Garage-Sale_W0QQssPageNameZstrkQ3amefsQ3amesstQQtZkm
I used the 1010 stock which is 1" X 1". After I built the frame I found that they had some 1050 stock that was 1" X .5". I would use that if I were to rebuild the frame. I'll post some pictures of the frame and how I connected it all together if anyone would like to see what I've done.
