RoboGames 2007 Scrolling LED Medal - not displaying robots?
I received·a 2007 RoboGames Scrolling LED Medal last week from Parallax (along with 2 of the required batteries). However, the picture indicates the 2 Robots but my medal does not show them.
When I power it up, I hear the·sound demo·and then it starts scrolling Parallax ....something and then the letters of the alphabet (I beleive). It repeats this but I never see the robots come on.
I assume I can reprogram it with the code from the Parallax site (using only the 2 required batteries).
What is going on here?·Is there another version of the code loaded into my medal?
http://www.parallax.com/detail.asp?product_id=28099
It comes with a header for the SX-Key on-board.
The code that is on the Medals is the test code installed during manufacturing…The source code is freely available and includes the little robots. You can download this code from the following page. Take care.
Chris Savage
Parallax Tech Support
I will do that tonight.
Dan
Display(15) = NextChr(0)
and
Display(15) = %00000000
I fixed·the program·by changing the dimensioning statement.
Display VAR Byte (15)
into·this....
Display VAR Byte (16)
Does this sound correct?
Does the SX28 have a 0 to 15 array or a 1-16 array?
Post Edited (T&E Engineer) : 6/29/2007 1:30:17 PM GMT
Chris Savage
See the picture. I·was chosen as an·SX/B Beta Tester.
I have updated the picture to show working vs original code.
Post Edited (T&E Engineer) : 6/29/2007 2:53:10 PM GMT
Chris Savage
The code will work because the memory location where Display(15) would be is not used by anything else. But the new compiler errors if you try to use an array element outside of the bounds.
You have done the right thing by changing the declaration to Byte(16). That will solve the problem.
Bean.
“The United States is a nation of laws -· poorly written and randomly enforced.” - Frank Zappa
www.hittconsulting.com
Chris Savage
It looks to me that the "j" loops should only go to 13 and the "Display(15)" lines should be "Display(14)".
But that's just a quick read thought, I don't have a metal handy to try it.
Bean.
Chris Savage
The text scrolling routines, SCROLL_LF and SCROLL_RT, can use inline strings or strings stored in DATA statements. If the DATA statement is used then you can embed a bell character (#7) into the string and the beeper will beep at that point while retrieving the next character (the beeper runs in the ISR). You can also embed a CLS (#12) character into the string. Scrolling speed is controlled with a variable so you can adjust this parameter before putting text on the screen.
This version of the program takes advantage of a subtle feature in SX/B: you can pass five parameters to a subroutine (or function) -- yes, five. To do this, however, you must pass exactly five (and the SUB or FUNC has to be defined that way). When this is the case the register that usually holds the parameter count (__PARAMCNT) is used as the fifth parameter (it is also aliased as __PARAM5). Here's how I use it in this program to play a set of animation frames:
' Use: PLAY_FRAMES Label, FrameCount, FrameTiming, Loops ' -- displays animation frames at "Label" ' -- "FrameCount" is number of 15-column frames in animation ' -- "FrameTiming" is display time for frame in milliseconds ' -- "Loops" is number of times to play frames sequence SUB PLAY_FRAMES tmpW2 = __WPARAM12 ' address of first frame tmpB1 = __PARAM3 ' number of frames tmpB2 = __PARAM4 ' delay between frames tmpB3 = __PARAM5 ' animation loops DO WHILE tmpB3 > 0 ' any loops left? tmpW3 = tmpW2 ' point to first frame tmpB4 = tmpB1 ' copy frame count DO WHILE tmpB4 > 0 FOR tmpB5 = 0 TO 14 ' grab a frame READINC tmpW3, dispBuf(tmpB5) ' move frame to display NEXT DELAY_MS tmpB2 ' hold DEC tmpB4 ' move to next frame LOOP DEC tmpB3 ' update loop count LOOP ENDSUBPost Edited (JonnyMac) : 7/1/2007 7:23:29 PM GMT
All I can say is WOW and Incredible!
Great job!
Now it's time to examine it closer to adapt it to my other project (if possible).
