Anyone know how to blank a separate 7-digit display on a MAX7219? — Parallax Forums
kingspudkingspud Posts: 128
edited 2007-06-26 22:55 in BASIC Stamp
Hello all,
I have created a program that can be used to show two separate scores for a horseshoe game.
The program uses three buttons:· one button for incrementing player 1's score from 1 to 21,
another button for incrementing player 2's score from 1 to 21
and
the third button to reset all the displays to blanks for a new game.
The problem I am having is when you push the player buttons both digit displays start with ZEROS and they stay on the displays!· I am hoping someone knows how to start the scoring with only the single digit when the score is less than 10 and not have a zero show up in the display.
So...· instead of a 01 when you first hit the player buttons, you get only a 1 on display.
Thanks for any help
The code is tested and works great
Joe
Here is the code:
I am using·the BS2px24, a MAX7219 chip, and the PDB board with four of the 7-segment displays.
“Intellectual growth should commence at birth and cease only at death”
Albert Einstein
  • kingspudkingspud Posts: 128
    edited 2007-06-24 19:08
    Sorry... here is the code
    ' {$STAMP BS2px}
    ' {$PBASIC 2.5}
    ' This program is used to create a score counter for Horseshoes
    'The program has two buttons that each count up by 1 to 21
    'The third button is used to reset the displays to all blanks
    [noparse][[/noparse] I/O Definitions ]
    '0 sets pin as input
    'button PIN 0 makes the word button = pin 0
    DIRS = $000E 'pins 1 2 3 output,all other pins outputs
    DOUT PIN 1 'pin 1 of stamp to pin 1 of 7219
    Load PIN 2 'pin 2 of stamp to pin 12 of 7219
    CLK PIN 3 'pin 3 of stamp to pin 13 of 7219
    [noparse][[/noparse] Constants ]
    IsLow CON 0
    IsHigh CON 1
    [noparse][[/noparse] Variables ]
    Digit0 VAR Word
    Digit1 VAR Word
    Digit2 VAR Word
    Digit3 VAR Word
    Value VAR Nib
    score1 VAR Word
    score2 VAR Word
    btn VAR Bit
    [noparse][[/noparse] Initialization ]
    Digit0 = $010F
    Digit1 = $020F
    Digit2 = $030F
    Digit3 = $040F
    score1=0
    score2=0
    [noparse][[/noparse] Main Program ]
    main:
    GOSUB DecodeMode
    GOTO reset
    loop1:
    BUTTON 10,0,255,250,btn,1,press0
    BUTTON 11,0,255,250,btn,1,press1
    BUTTON 12,0,255,250,btn,1,press2
    GOTO loop1
    press0: 'Player 1 Press BUTTON [noparse][[/noparse]0] ON PIN 10 AND GOTO player1
    GOSUB DecodeMode
    GOTO player1
    press1: 'Player 2 Press BUTTON ON PIN 11 AND GOTO player2
    GOSUB DecodeMode
    GOTO player2
    press2: ' Reset Press BUTTON ON PIN 12 AND GOTO Reset
    GOSUB DecodeMode
    GOTO reset
    [noparse][[/noparse] GOSUB RESET ]
    reset:
    LOW Load
    SHIFTOUT DOUT, CLK, MSBFIRST,[noparse][[/noparse]$0900\16]
    HIGH Load
    score1 = 1
    score2 = 1
    Digit0 = $0100 'BLANK
    Digit1 = $0200 'BLANK
    Digit2 = $0300 'BLANK
    Digit3 = $0400 'BLANK
    GOSUB board_display:
    GOTO loop1
    [noparse][[/noparse] GOSUB player1 ]
    player1:
    IF score1 < 10 THEN
    Digit0 = score1 DIG 0 + $0100
    ENDIF
    IF score1 >= 10 THEN
    Digit1 = score1 DIG 1 + $0200
    ENDIF
    IF score1 => 21 THEN
    score1 = 20
    ENDIF
    score1 = score1 + 1
    GOTO loop1
    [noparse][[/noparse] GOSUB player2]
    player2:
    IF score2 < 10 THEN
    Digit2 = score2 DIG 0 + $300
    ENDIF
    IF score2 >= 10 THEN
    Digit2 = score2 DIG 0 + $0300
    Digit3 = score2 DIG 1 + $0400
    ENDIF
    IF score2 => 21 THEN
    score2 = 20
    ENDIF
    score2 = score2 + 1
    GOTO loop1
    [noparse][[/noparse] Subroutines ]
    'Decode mode for no decoding to BCD
    'Least sig nibble:
    '0 = no decode
    '1 = decode Digitit 0
    'F = decode Digitits 0-3
    'FF = decode Digitits 0-7
    DecodeMode:
    LOW Load
    SHIFTOUT DOUT, CLK, MSBFIRST,[noparse][[/noparse]$090F\16]
    HIGH Load
    RETURN
    board_display:
    LOW Load
    SHIFTOUT DOUT, CLK, MSBFIRST,[noparse][[/noparse]Digit0\16]
    HIGH Load
    LOW Load
    SHIFTOUT DOUT, CLK, MSBFIRST,[noparse][[/noparse]Digit1\16]
    HIGH Load
    LOW Load
    SHIFTOUT DOUT, CLK, MSBFIRST,[noparse][[/noparse]Digit2\16]
    HIGH Load
    LOW Load
    SHIFTOUT DOUT, CLK, MSBFIRST,[noparse][[/noparse]Digit3\16]
    HIGH Load
    PAUSE 400
    RETURN
    clear:
    LOW Load
    HIGH Load
    RETURN
    Albert Einstein
    edited 2007-06-24 20:44
    kingspud,
    Try this for your BLANK routines towards the top of your program...
    Digit0 = $010F 'BLANK
    Digit1 = $020F 'BLANK
    Digit2 = $030F 'BLANK
    Digit3 = $040F 'BLANK
    ...in your initialization routine AND your reset routine.
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 6/24/2007 8:49:35 PM GMT
  • Nick WaldvogelNick Waldvogel Posts: 71
    edited 2007-06-24 21:47
    Here is some cose that I used for a clock and temp display.· Maybe there is something in there that will help out?· Let us know how you fixxed it.
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    DataIO····· PIN···· 15························· ' 1302.6/1620.1/7219.1
    Clock······ PIN···· 13························· ' 1302.7/1620.2/7219.13
    Decode····· CON·· 9···························· ' Decode register; a 1 turns on BCD decoding.
    Brite······ CON·· 10··························· ' "······ "·· " intensity register.
    Scan······· CON·· 11··························· ' "······ "·· " scan-limit register.
    Switch····· CON·· 12··························· ' "······ "·· " on/off register.
    Test······· CON·· 15··························· ' Activates test mode (all digits on, 100% bright)
    T·········· CON·· %1111
    P·········· CON·· %1010
    CWPr······· CON·· $8E·························· 'Write Protect Register
    WPr1······· CON·· $80·························· 'Set Write Protect
    RdBurst···· CON·· $BF·························· 'Read Burst Of Data
    DecPnt····· CON·· %10000000···················· 'Decimal Point
    Hr24······· CON·· 0···························· '24 Hour Mode
    Hr12······· CON·· 1···························· '12 Hour Mode
    Blank······ CON·· %1111························ 'Blank A Digit
    X·········· VAR·· Word························· 'General purpose variable, byte.
    DegF······· VAR·· Word························· 'Variable for Deg F.
    DegC······· VAR·· Word
    Sign······· VAR·· X.BIT15······················ 'Sign bit of X
    Index······ VAR·· Byte························· 'Variable for Initialization of Max7219
    Index1····· VAR·· Byte
    Value1····· VAR·· Byte
    Value2····· VAR·· Byte
    Value3····· VAR·· Byte
    MaxTemp···· VAR·· Word························· 'Variable used for Initialization of Max7219 - Temp
    Odd········ VAR·· Index.BIT0··················· 'Lsb of Index.
    Reg········ VAR·· Byte························· 'Read/Write Address
    IoByte····· VAR·· Byte························· 'Data To/From Devices
    d7219······ VAR·· Byte························· 'Data For MAX7219
    Secs······· VAR·· Byte························· 'Seconds
    Mins······· VAR·· Byte························· 'Minutes
    Hrs········ VAR·· Byte························· 'Hours
    Date······· VAR·· Byte························· 'Date
    Month······ VAR·· Byte························· 'Month
    Day········ VAR·· Nib·························· 'Day
    Year······· VAR·· Byte························· 'Year
    modeFlag··· VAR·· Bit·························· '0 = 24, 1 = 12 (Hours)
    ampmFlag··· VAR·· Bit·························· '0 = AM, 1 = PM
    Initialization
    FREQOUT 3, 1000, 3800
    'Max7219 for Temp
    FOR Index = 0 TO 7····················· ' Retrieve 8 items from table.
    · LOOKUP index,[noparse][[/noparse]Scan, 3, Brite, 15, Decode,$FF, Switch,1],MaxTemp
    · SHIFTOUT DataIO, Clock,MSBFIRST,[noparse][[/noparse]MaxTemp]
    · IF Odd = 0· THEN NoLoad·············· 'If odd is 1, pulse Load line.
    · PULSOUT 14,5························· 'Latch The Data
    NoLoad:································ 'Else, don't pulse.
    NEXT··································· 'Get next item from table.
    'Max7219 for Clock
    FOR Index = 0 TO 7····················· ' Initialize MAX7219
    · LOOKUP index, [noparse][[/noparse]Scan, 3, Brite, 15, Decode, $FF, Switch, 1], d7219
    · SHIFTOUT DataIO, Clock, MSBFIRST, [noparse][[/noparse]d7219]
    · IF Odd = 0 THEN NoLoad2
    · PULSOUT 12, 5··················· ' Latch The Data
    NoLoad2:································ 'Else, don't pulse.
    'DS1620
    HIGH 0································· 'Select the DS1620.
    SHIFTOUT 2, 1, LSBFIRST, [noparse][[/noparse]238]········· 'Send the "Start Conversions" command.
    LOW 0·································· 'Do the command.
    'DS1302
    Reg = CWPr····························· ' Initialize DS1302
    IoByte = WPr1·························· ' Set Write Protect
    · HIGH 11······························ ' Select DS1302
    · SHIFTOUT DataIO, Clock, LSBFIRST, [noparse][[/noparse]reg, ioByte]
    · LOW 11······························· ' Deselect DS1302
    Main_Program
    Main:
    DO
    · GOSUB Get_Temp························ 'Get Current Temp
    · GOSUB Temperature_Display_Table······· 'Get Index VAR for Temp display
    · GOSUB Display_Temp···················· 'Update 7-Seg Display
    · GOSUB Get_Time························ 'Get Current Time/Date Data
    · GOSUB Show_Time······················· 'Update 7-Seg Display
    · GOSUB Door_1_Switch··················· 'Check if door 1 is Open or Closed
    · DEBUG " ", HEX2 month, "/", HEX2 date, "/", HEX2 year, " " ,HEX2 hrs, ":", HEX2 mins," [noparse][[/noparse]", HEX2 secs, "]"
    LOOP
    '----Get_Temp_Sub
    Get_Temp:
    · SHIFTOUT 2, 1, LSBFIRST, [noparse][[/noparse]170]······· 'Send the "Get Data" command.
    · SHIFTIN 2,1,LSBPRE, [noparse][[/noparse]X\9]············ 'Get the data.
    LOW 0·································· 'End the command.
    ·· X.BYTE1 = -x.BIT8··················· 'Extend the sign to 16 bits
    ·· degC=x*5···························· 'Convert to 'C*10 (resolution 0.5 'C)
    ·· degF= degC+2732*9/50-459············ 'Convert to Fahrenheit
    · DEBUG HOME··························· 'Set Debug to Home Position
    · DEBUG "The Temp is ",DEC DegF,32,"Degrees", CR· 'Display The Temp in Debug
    · RETURN································· 'Return to where you came from.
    '----Display_Temp_Sub
    Display_Temp:
    'Diget #1
    ··· SHIFTOUT 15,13,MSBFIRST,[noparse][[/noparse]01]······· 'Send digit 1 position.
    ··· SHIFTOUT 15,13,MSBFIRST,[noparse][[/noparse]8]········ 'Send the digit.
    ··· PULSOUT 14,1······················· 'Load the display.
    'Diget #2
    · LOOKUP Index1, [noparse][[/noparse]0,9,8,7,6,5,4,3,2,1,0,9,8,7,6,5,4,3,2,1,0,9,8,7,6,5,4,3,2,1,0,9,8,7,6,5,4,3,2,1,0,9,8,7,6,5,4,3,2,1,0,1,2,3,4,5,6,7,8,9,0,1,2,3,4,5,6,7,8,9,0,1,2,3,4,5,6,7,8,9,0,1,2,3,4,5,6,7,8,9,0,1,2,3,4,5,6,7,8,9,0,1,2,3,4,5,6,7,8,9,0,1,2,3,4,5,6,7,8,9,0,1,2,3,4,5,6,7,8,9,0,1,2,3,4,5,6,7,8,9,0,1,2,3,4,5,6,7,8,9,0,1,2,3,4,5,6,7,8,9,0,1,2,3,4,5,6,7,8,9,0], value1
    ··· SHIFTOUT 15,13,MSBFIRST,[noparse][[/noparse]02]······· 'Send digit 2 position.
    ··· SHIFTOUT 15,13,MSBFIRST,[noparse][[/noparse]Value1]··· 'Send the digit.
    'Diget #3
    · LOOKUP Index1, [noparse][[/noparse]5,4,4,4,4,4,4,4,4,4,4,3,3,3,3,3,3,3,3,3,3,2,2,2,2,2,2,2,2,2,2,1,1,1,1,1,1,1,1,1,1,%1111,%1111,%1111,%1111,%1111,%1111,%1111,%1111,%1111,%1111,%1111,%1111,%1111,%1111,%1111,%1111,%1111,%1111,%1111,1,1,1,1,1,1,1,1,1,1,2,2,2,2,2,2,2,2,2,2,3,3,3,3,3,3,3,3,3,3,4,4,4,4,4,4,4,4,4,4,5,5,5,5,5,5,5,5,5,5,6,6,6,6,6,6,6,6,6,6,7,7,7,7,7,7,7,7,7,7,8,8,8,8,8,8,8,8,8,8,9,9,9,9,9,9,9,9,9,9,0,0,0,0,0,0,0,0,0,0,1,1,1,1,1,1,1,1,1,1,2], Value2
    ··· SHIFTOUT 15,13,MSBFIRST,[noparse][[/noparse]03]········· 'Send digit 3 position.
    ··· SHIFTOUT 15,13,MSBFIRST,[noparse][[/noparse]Value2]····· 'Send the digit.
    ··· PULSOUT 14,1························· 'Load the display.
    'Diget #4
    · LOOKUP Index1, [noparse][[/noparse]P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,P,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,T,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1], Value3
    ··· SHIFTOUT 15,13,MSBFIRST,[noparse][[/noparse]04]········· 'Send digit 4 position.
    ··· SHIFTOUT 15,13,MSBFIRST,[noparse][[/noparse]Value3]····· 'Send the digit.
    RETURN··································· 'Return to where you came from.
    Temperature_Display_Table_Sub
    Temperature_Display_Table:
    LOOKDOWN DegF, [noparse][[/noparse]-50,-49,-48,-47,-46,-45,-44,-43,-42,-41,-40,-39,-38,-37,-36,-35,-34,-33,
    ················ -32,-31,-30,-29,-28,-27,-26,-25,-24,-23,-22,-21,-20,-19,-18,-17,-16,-15,
    ················· -14,-13,-12,-11,-10,-9,-8,-7,-6,-5,-4,-3,-2,-1,0,1,2,3,4,5,6,7,8,9,10,11,
    ·················· 12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,
    ··················· 37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,
    ···················· 62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,80,81,82,83,84,85,86,
    ····················· 87,88,89,90,91,92,93,94,95,96,97,98,99,100,101,102,103,104,105,106,107,108,
    ······················ 109,110,111,112,113,114,115,116,117,118,119,120], Index1
    Get_Time_Sub
    Get_Time:······························ ' DS1302 Burst Read
    · SHIFTOUT DataIO, Clock, LSBFIRST, [noparse][[/noparse]RdBurst]
    · SHIFTIN DataIO, Clock, LSBPRE, [noparse][[/noparse]secs, mins, hrs, date, month, day, year]
    · LOW· 11······························ ' Deselect DS1302
    ···· IF mins = $00 AND secs = $00 THEN
    ···· GOSUB Hourly_Chime
    ···· ENDIF
    · RETURN
    Show_Time_Sub
    Show_Time:
    'Diget #1
    · index = 1···························· ' Select Digit 1
    · d7219 = mins.LOWNIB·················· ' Seconds (Ones Digit)
    GOSUB Show_Max_Time
    'Diget #2
    · Index = 2···························· ' Select Digit 2
    · d7219 = mins.HIGHNIB················· ' Seconds (Tens Digit)
    GOSUB Show_Max_Time
    'Diget #3
    · Index = 3···························· ' Select Digit 5
    · d7219 = hrs.LOWNIB··················· ' Hours (Ones Digit)
    GOSUB Show_Max_Time·················· ' ^ PM Indicator
    'Diget #4
    ·index = 4···························· ' Select Digit 6
    · IF(hrs.HIGHNIB = %1011) THEN
    · d7219 = 1
    · ELSE
    · d7219=blank
    · ENDIF
    · d7219 =d7219························ ' Blank Digit
    GOSUB Show_Max_Time
    RETURN
    Show_Max_Time_Sub
    Show_Max_Time:
    · SHIFTOUT DataIO, Clock, MSBFIRST, [noparse][[/noparse]Index, d7219]
    · PULSOUT 12, 5··················· ' Latch Data
    RETURN
    Hourly_Chime_Sub
    Hourly_Chime:
    ··· FREQOUT 3, 100, 3800
    ··· PAUSE 100
    ··· PAUSE 100
    RETURN
    edited 2007-06-25 01:12
    Joe,
    In the Binary Digital Clock Project in the Completed Projects Forum I needed to keep the leading digit on the clock blank for times from 1:00 through 9:00 until it rolled over to 10:00. The code on that page may help you. It is fully documented and commented. I hope this helps. Take care.
    http://forums.parallax.com/showthread.php?p=552892
    Chris Savage
    Parallax Tech Support
    edited 2007-06-26 15:16
    Hello all,
    So far I have tested Beau Schwabe·code and here are the results.
    When I replaced the following code in the reset gosub with my code:
    Digit0·=·$010F·'BLANK
    Digit1·=·$020F·'BLANK
    Digit2·=·$030F·'BLANK
    Digit3·=·$040F·'BLANK
    I received the following results...
    When I turned on the device I initially get [noparse][[/noparse]4] small letter t's across all·[noparse][[/noparse]4] displays.
    Then when you hit either player's button the displays blank and you only see a 1 on either of the player's displays... so this example works great BUT...
    How do I get the small letter t to not show up on each display when I either hit reset or turn the power on?
    I have done some investigating and found that '0F' is the hex equivalent to the small letter t and if I change the 0F value to anything else I get the corresponding display value for that hex code.
    Yet... if I put in '00', which is the equivalent to a blank the displays with show zeros when I hit reset or a player button!· Why is this?· And also... why does the display go from a small t to a blank
    When I hit the player button?· The·only thing I did was add the above mentioned code and I don't understand who it causes the displays to blank during the player button hits?
    Thanks Beau,
    I will test the other examples very soon and see what they do to help.
    Thanks everyone and I hope this explanation helps.
    Joe
    Albert Einstein
    edited 2007-06-26 15:18
    Also...
    Beau, when you say place in your initialization routine, where is it you are talking about?
    Albert Einstein
    edited 2007-06-26 19:31
    How about right below the line in your code that says "Initialization" (toward the top)
    - Stephen
    kingspud,
    According to the datasheet on page 8, a $0F should be a "blank" not a small 't'
    datasheets.maxim-ic.com/en/ds/MAX7219-MAX7221.pdf
    "Beau, when you say place in your initialization routine, where is it you are talking about?"
    If you look at your original code that you posted, the first lines read...
    ' -----[noparse][[/noparse] Initialization ]--------------------------------------------------
    Digit0 = $010F
    Digit1 = $020F
    Digit2 = $030F
    Digit3 = $040F
    ...which looks correct. If you look further down in your reset routine, the code looks like this...
    ...which according to the datasheet looks incorrect.
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 6/26/2007 10:59:54 PM GMT
