Building a 120 VAC power supply for my SX.
Sorry, but I don't know enough about electronics to design a power supply circuit to power my SX 28. I need a very small circuit
to convert 120 VAC to DC 5V, with just enough ma to power up the SX28 and one solid state relay.
http://www.allelectronics.com/cgi-bin/item/SRLY-25/500500/10_AMP_SOLID-STATE_RELAY,_USED_.html
How much power does the SX actually use up, with the relay, I can't seem to figure this out. Would it save space in my design to build a
transformer circuit that exactly fits the amount of power needed? i.e. Smaller transformers?? I need the entire circuit, power
supply, sx28 and relay to fit in a small plastic enclosure, thats why I can't use a regular wall wart.
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=102517&pa=102517PS
then you can use a bridge rectifer to convert the AC to DC
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=178183
Then use something like a LM2937 to regulate the 5vdc
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=297810
And if you read the datasheet that comes with the LM2937 on page 6 at the bottom shows you a schematic to make a regulated voltage.
http://www.jameco.com/Jameco/Products/ProdDS/297810NSC.pdf
I hope this helps..
Greetings from Germany,
G
In general, the wall wart will be smaller than anything you can build with discrete components and is likely to be much cheaper - the tranformer and all the circutry is optimized for size. About the only exception would be a 'transformerless design', but not using a transformer creates a very serious safety hazard in the form of electrical shock.
If you must, you can hack off the AC plug ins and solder an electrical cord. Similarly, you can eliminate most of the cord on the DC side.
The solid state relay is likely to use less than 10ma on the SX side as it usually just turns on an optoisolator's LED. You can easily get by for less than 100ma total power supply, but it is really hard to find anything less than 500ma in a wall wart or transformer. I suppose you could wind your own, but would it really be smaller? Where would you get the components to do so? That Jamco 300ma transformer is quite unusual. Don't forget your rectifier bridge and filter capacitors.
"Everything in the world is purchased by labour; and our passions are the only causes of labor." -- David·Hume (1711-76)········
Gunther mentioned that I can operate the SX at 3.3v.. How about 3v? http://www.allelectronics.com/cgi-bin/item/DCTX-31/815/3VDC_100MA_WALL_TRANSFORMER_.html At $1.25 a piece, not bad!, but only if it would work with the SX. This one is a little bit bigger than the one i mentioned, judging from the reference I am making with the plug it has,, but its dirt cheap..
G
HTH, Chris
My guess is that you will use far less than 100ma [noparse][[/noparse]Guenther says 10 ma is a likely right], unless it is a huge relay. Likely 10ma for the SXes general functioning and 25ma maximum for the one relay pin.
The way to accurately find out is to build the device and measure the current draw during actual use.
Of course we all understand that you might want to skip that tedious step. That is normal human nature.
In this case, I truly belive that you won't find anything in a 120VAC supply that provides under 600ma because most if not all these supplies are intended to regard lithium batteries. There is not much reason to build a small supply as it would just slow down charging and the size is about as small as it can physically get.
So why worry?
