Variable Frequency
Anyone have any good ideas for varying 60hz 110 volts A/C very quickly between say 30.0 - 40khz?·(Not a VF drive as I do not think it would·ramp fast enough)
The load would only be a couple amps. I am thinking maybe taking the 110vac 60hz, converting it to DC, modify the frequency then convert back to 110vac with the new frequency.
any good ideas out there?
I plan to use the propeller for the frequency programming.
You want to convert 110/60 to DC (a linear power supply), then convert that to a higher frequency (a frequency generator) supplying a couple of Amps (a POWERFUL frequency generator), then convert that back to DC (the back end of a switching supply), 'modify' the DC to a frequency (here we go again), and lastly change THAT to 110/60 (at 2 Amps or so?). You start with 110/60 and end with 110/60. Why did you bother with all that stuff in between? I'm intrigued. What did I miss here?
'Luck!
kenjj
I understand wanting to change frequencies for certain jobs. I agree, a VFD is certainly not going to get up to that frequency.
But what, pray tell, would need 110 volts at 40 kHz? Is this some kind of honking big ultrasonic thing?
As usual, more details are better than fewer details when looking for help.
Cheers,
Tom Sisk
http://www.siskconsult.com
110VAC 60hz line voltage input. End result output would be 110VAC 30.0 - 500hz variable.
I wanted a wide range of adjustability but will settle for 500hz and expand later.
Why you ask?
60hz is a musical note. As you vary the frequncy, the note changes. I want to play music with voltage.
There are frequency to voltage (F->V) chips as well as voltage to frequency (V->F) chips available, but none that I know of will work with line voltage. Besides that, line voltage would be rather dangerous for any sort of musical instrument in my mind.
As far as specific chips are concerned, here is one which will go in either direction (V->F or F->V):
http://focus.ti.com/docs/prod/folders/print/vfc32.html
and, samples are available!
Bruce Bates
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
