PINK program help
Hello, How do I get the PINK variable <NB_var01> into a JavaScript variable? I'm sure its simple but I have little experience in programming in HTML or JavaScript.
I've tried the following without success:
1. var·myvalue = document.getElementsByName('NB_var01').value; //undefined
2. window.status = <NB_var01>;· //errors out
Thanks, any help will be appreciated.
Paul
Paul
I have contacted the developer of the firmware to see if this is supported and how. I will post what I find. Take care.
Chris Savage
Parallax Tech Support
Thanks for sharing your success. This could help others in the future. Take care.
Chris Savage
I decided to do a little playing around myself since one of my test applications is a remote security station. In order for it to work I need the web page to refresh every 5 seconds (very easy to do) and update the information on the page. But more importantly I need to detect when a variable is set to a certain value and cause the page to redirect. I am doing this with JavaScript and this required me to figure out how to get the variable into a JS variable. Please see the attached snippet from my PINK test page. I hope this helps someone out. Take care.
The above example jumps to Google when the variable <Nb_var00> changes to the word SEARCH. ·Note that this is exactly what I am using but it should get the point across.· Note also that you don't need the document.writeln section...I was using that to debug the variable information.
Chris Savage
Post Edited (Chris Savage (Parallax)) : 6/20/2007 7:34:25 PM GMT
Paul
Doing it that way let’s you bring it right into the JavaScript variable…Nice and easy. Take care.
Chris Savage
Chris Savage
