I am using HAM for the next SpaceWar! release. Trying to get a version out tonight. I have run into several bugs with 1.07 so I've switched back to 1.06 for now.
1) The app searches the current directory for the HAM driver, but the current directory changes if you load a project or assets from a directory other than the one HAM is stored in. If I load a project from another directory and then try to upload the driver, HAM fails to find it.
2) The Memory Map does not scale when I change the EEPROM size. It seems appears to always be scaled for 64K, but I am using 128K (Hydra).
3) When I tried using the benson_ham_driver_1_07.spin & eeprom files in your most recent post (3 posts back) the driver never started on my Hydra (screen stayed black). I switched back to the driver in the 1.07 release .zip and that one worked fine for what I was doing.
4) If you run Help->About it also searches the current directory for the .rtf help file. Again if you've loaded a project file from another directory it can't find the help file anymore.
Hi Epmoyer, the 3 posts back version is my version, I forgot to change it back from Protoboard to Hydra setup
So it'll have wrong clock speed and wrong pins for TV out.
I've attached Hydra versions, let me know if this fixes it.
Ah, I'll have to fix that current directory logic.·
As for the memory map, does it correct itself if you hit PgUp/PgDn?· I may have forgot a refresh call after the size changes.
I need to incorporate Baggers fixes into a new official release instead of this 1.07 + forum attachments version [noparse]:)[/noparse]
Yup! PgUp/PgDn fixes the scaling. I like the way the asset names collect on the top of the window as you scroll down; that looks really cool.
SpaceWar! has gone HAM as of version 2.5, and uses the upper EEPROM memory to store its title screen, option screen, and music assets. Thanks of all your hard work.
epmoyer said...
FYI, the first post has been updated to include the 1.0.8. release.
epmoyer, the current directory logic has been fixed.
Baggers, thanks for the updated .eeprom and .spin. Those have been included in the 1.0.8. release. One side note, the video settings were causing problems so I had to change them back to what I had in 1.0.7. Not sure what effect that will have on the non-Hydra people.
Looks like you still had wireless video enabled as well as having some tweaks to the normal video flags.
long %011_0001 'pins - wireless video
' long %001_0101 'pins - normal video
1.0.8 is back to these settings.
' long %011_0001 'pins - wireless video
long %011_0000 'pins - normal video
This fixes a few bugs that Marko Lukat pointed out.
You couldn't add an asset at the end of memory if it was a perfect fit.
Various issues with the zoom level and different memory sizes.
I also removed the check that prevented project files from older versions from loading. This will be reworked if/when the project format changes or I'll move to a tag-based, change-tolerant version.
Hi Everyone, it is 5 years since this page in the forum has been used but I have just come across this page and the references to "Hydra Asset Manager" and some of the functions seem ideal for my project but I can't find the latest source code anywhere to give it a try. There seems to be nothing in the Object Exchange and most of the references in the discussion go to Blank pages except for "benson_ham_driver_1_07" .eeprom & .spin but can see that there is at least a version "HAM_1_09.zip" mentioned that I can't find. Anyone have a latter version they can upload and does anyone here know anything about how to use this program? Long shot I know but I thought it was asking. Thanks all
Cheers and soz
Baggers.
Rich
Paul Baker
long %011_0001 'pins - wireless video ' long %001_0101 'pins - normal video1.0.8 is back to these settings.
' long %011_0001 'pins - wireless video long %011_0000 'pins - normal videohttp://forums.parallax.com/showthread.php?p=628778
Post Edited (Keebler) : 5/19/2008 11:54:19 PM GMT
Here's a download link. I updated the first post as well.
http://forums.parallax.com/attachment.php?attachmentid=90044&d=1330294165
I'm attaching the latest version.
HAM_1_09.zip
