Multivoltage DC Regulator
Hey everyone,
Quick question: Has anyone heard of a power regulator similar to an NTE960/NTE966 that can output 12,9,5 volts in one pack instead of using 3?
http://www.nteinc.com/specs/900to999/pdf/nte960.pdf
-Pat Alonzi
palonzi@ecn.purdue.edu
-Pat Alonzi
I've not heard of an integrated voltage regulator that has multiple outputs. It wouldn't make sense from a design or marketing perspective.
There are variable voltage regulators and most fixed voltage regulators can also be made to regulate voltages higher than their specified voltage by using a voltage divider as shown on their datasheets. These are still single output regulators.
There are certainly multi-voltage power supplies that can produce nearly any voltage or set of voltages that you might need, but that's certainly not a "one-chip" solution, as you had hoped for.
Just out of curiosity, what is it that requires 9 volts?
Lastly, what kind of amperage are you going to require, as a voltage regulator may not be the only solution? The lower the current requirement, the better chance of a possible, alternate solution.
Bruce Bates
Post Edited (Bruce Bates) : 6/20/2007 2:48:58 PM GMT
Paul Baker
