Loop Never ?
LOOP NEVER
What do I use this command in/for?
I checked the assembly code and I found it completely empty from any commands!
It just defined two labels without any commands.
Let's say you wanted to do something if (A = 1) OR (B = 2)
You would use
DO
· IF A <> 1 THEN
··· IF B <> 2 THEN EXIT
· ENDIF
· ' Do whatever here
LOOP NEVER
Notice that must use the opposite condition in the IF statements (<> instead of
Bean.
“The United States is a nation of laws -· poorly written and randomly enforced.” - Frank Zappa
www.hittconsulting.com
DO
· IF A <> 1 THEN
·IF B <> 2 THEN EXIT
Is to mean that if A and B are not( "="· to 1 OR 2 ) then it will Not Loop
and only goto ' Do whatever here but is that what the EXIT Dose
Or is to mean that it only loop ONE TIME
·' Do whatever here
LOOP NEVER
I am not understanding what This Means LOOP NEVER
What dose the NEVER tell it to do· or look for
I understand what·LOOP means and what it dose
I understand what· <> means NOT = to what you are looking at
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 6/19/2007 4:30:13 PM GMT
SX/B does not allow multiple conditions for an IF...THEN statement.
But the code I posted does the same thing.
"LOOP NEVER" means to never loop, or the same thing as "LOOP UNTIL A·= A"
Bean.
Evaluation: IF a <> 1 THEN IF b <> 2 THEN GOTO Evaluation_Failed ENDIF ENDIF Evaluation_Succeeded: ' handle it GOTO Next_Process Evaluation_Failed: ' handle it Next_Process: ' handle itOne of the things that the SX/B reveals is that many of our *fancy* programming structures, things like IF-THEN-ELSE, are executed with simple test-and-jump code with the compiler automating the labels that I created manually in the example above.
Evaluation:
··IF·a·<>·1·THEN
····IF·b·<>·2·THEN
······GOTO·Evaluation_Failed
····ENDIF
··ENDIF
··'·handle·it
··GOTO·Next_Process
Evaluation_Failed:
··'·handle·it
Next_Process:
··'·handle·it
Thank You·For explaning it this way
Now·I understand what you are talking about
··Thanks for any·
Sam
