Identifying stamp by code
I'm trying to identify a basic stamp via the serial port using the IdentifySequence. Using vb.net, my code consists of the following:
'Identify Sequence:
Dim MyPort As SerialPort = New SerialPort("COM1", 9600, Parity.None, 8, StopBits.One)
MyPort.Open()
'ResetSequence is performed by hidden code at this point.
MyPort.Write("B") 'Tramsnits a capital B (ASCII 66)
Console.WriteLine("Echo Returned: " & MyPort.ReadByte) 'Receives the echo byte of "B"
Console.WriteLine("Next Byte Returned: " & MyPort.ReadByte) 'Should be ASCII 190 (2's complement of "B")
The code executes properly and returns the echo of the transmitted "B" correctly, but then hangs on the second .ReadByte as though the Stamp never transmits another character and waits forever for another byte that it never receives--which should be the ASCII 190 (I'm using a BS2)
Am I missing something in the transmission/receiving protocol?
'Identify Sequence:
MyPort.Open()
I asked for help on a previous post·, the post contains a link from Tracy Allen which contains some very useful information be sure to check it out this is the link.
http://forums.parallax.com/showthread.php?p=651172
Jeff T
Your code looks functionally identical to mine: A single write followed by two ReadBytes. Mine however, still hangs at the second ReadByte and never seems to receive the byte after the echo byte.
I've seen Tracy's link--it is very informative, but I haven't seen anything different from what I (and your example) have done.
I've tested my reset sequence and it *does* perform the reset (the code in the stamp starts again properly immediately thereafter).
Any other thoughts what might prevent the return byte from being sent (or received)?
I can't really say any more without seeing the rest of your listing.
Jeff T.
dtr=true
sleep(2)
dtr=false
break=true
sleep(48)
break=false
sleep(5)
readexisting
gosub ID
the timing and order is fairly critical, let me know your progress after you have tried this. In case you wanted to see what the output should be I have attached the test sample I used.
Jeff T.
I played with the order of the commands, and it appears that your changes (which are different from the documentation provided by parallax) make the difference. You mentioned that you had made a "couple subtle changes". It appears that those make all the difference.
Parallax docs indicate the overlapping of the flags/waveforms, and this *does not appear to work*. I'm guessing that this is an error in the documentation provided with the tokenizer api. The corrected code pulses the DTR line, *then* pulses the break state.
I appreciate the help!
It’s not that there’s an error…On USB-based systems things work better if the break is initiated just before the DTR pulse, as I recall. But the way things are documented should be working at least on serial systems. Take care.
Chris Savage
Parallax Tech Support
I'm using straight serial on my test system. I haven't attempted to test a USB system yet. I used the documented version and it failed. Leave it to me to be outside the norm [noparse];)[/noparse]
I'll suggest that this information be added (about USB vs. serial) to the tokenizer documentation to avoid these problems.
I wasn’t suggesting the USB wouldn’t work…However there is an issue with latency on some USB systems which causes problems with identification and programming. Usually we have the customer reduce the latency setting. This is more prevalent on laptops. By the way…I programmed a BASIC Stamp 2p24 to ID any BASIC Stamp connected to it using solely the Tokenizer documentation. It worked fine. The BS2p24 was connected to the destination BASIC Stamp programming pins and power. Take care.
Chris Savage
Are you moving on to the Tokenizer library or using·reset/ID·for some other purpose. If you do use the library I would be interested in your progress, last time I messed with it I was having difficulty .
Jeff T.
