Full Duplex Serial Question
So, here's another opportunity for my ignorance to show with the full duplex serial object.· If I have multiple devices connected to one prop, say 5... that use a serial interface, is there a way to use the same fdx object for all devices or perhaps another way to save memory... or do I need to·call the object 5 times in the OBJ section?·
Any help is appreciated
Have you tried sharing one object between multiple routines by switching the pin numbers and restarting the object? (ser.stop, reassign pins, ser.start, etc...) Is there any issues I'm not thinking of with that? Or does it really not gain much of an advantage.. I'm straining for memory space so anything I can eek out right now helps.
Thanks=)
