Have anybody tried to control a 64128 graphics lcd with KS0713 ic (with serial
I looked at some PIC code for serial control of a Graphic LCD display (64x128 pixels) with a KS0713 chip on glass controller and tried to convert the PIC code for use with the propeller, with little luck.
I want to use the rest of the pins on the propeller for other purposes, so I am left with five pins and that should be enough to control the KS0713 LCD controller, but the display seems dead.
Have anybody tried to access one of these panels serially with the propeller? I have checked my hardware and it seems OK. All capacitors for the charge-pump and internal PSU is okay and the display gets the correct 3,3V voltage.
I think I have a problem with the serial shift-out routine.
Can anybody help?
Can anybody help?
If you're really intent on just converting the PIC code to Propeller, post what you have along with a description of the behavior you're seeing·and someone will offer help.
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
CS1B = 16
RST = 17
RS = 18
CLK = 19
DATA = 20
BITS = 8
VAR
PUB Main
dira[noparse][[/noparse]CS1B]~~ ' SET THE LCD CONTROL PINS AS OUPUTS
outa[noparse][[/noparse]RST]:=0
dira[noparse][[/noparse]RST]~~
outa[noparse][[/noparse]RST]:=0 ' SET THE RESET PIN LOW
dira[noparse][[/noparse]RS]~~
outa[noparse][[/noparse]RS]:=0
dira[noparse][[/noparse]CLK]~~
outa[noparse][[/noparse]CLK]:=0
dira[noparse][[/noparse]DATA]~~
outa[noparse][[/noparse]DATA]:=0
waitcnt(100_000 + cnt) ' WAIT
outa[noparse][[/noparse]RST]:=1 ' SET THE RESET PIN HIGH FOR NORMAL OP.
outa[noparse][[/noparse]CS1B]:=0 ' SET THE CS1B PIN LOW FOR WRITE OP.
waitcnt(100_000 + cnt) ' WAIT FOR LCD TO SETTLE
outa[noparse][[/noparse]RS]:=0 ' SET RS PIN LOW FOR LCD COMMANDS
SEROUT ($E2) ' SEND RESET COMMAND FOR ALL LCD REGS.
SEROUT ($A0) ' SELECT SEG OUTPUT DIR : ADC=0
SEROUT ($C0) ' SELECT COM OUTPUT DIR : SHL=0
SEROUT ($A2) ' SELECT LCD BIAS
SEROUT ($2F) ' TURN ON VOL. CONV, REG, VOLT FOLLOWER
SEROUT ($26) ' SELECT THE REG. RESISTOR
SEROUT ($81) ' 1ST INSTRUCTION SET REF. VOLT. REG.
SEROUT ($20) ' 2ND INSTRUCTION REG
SEROUT ($A4) ' NORMAL DISPLAY
SEROUT ($A6) ' REVERSE DISPLAY OFF
SEROUT ($AF) ' TURN ON THE LCD
' INIT DONE - DRAW SOMETHING ON LCD
SEROUT ($40) ' INITIAL DISPLAY LINE
SEROUT ($B0)
SEROUT ($14) ' SET MSB COL. ADDRESS
SEROUT ($00) ' SET LSB COL. ADDRESS
outa[noparse][[/noparse]RS]:=1 ' SET RS PIN HIGH FOR LCD DATA
SEROUT ($F0) ' DISPLAY DATA - TEST
PUB SEROUT (TX_BYTE) ' MSB FIRST SERIAL OUT ROUTINE
REPEAT (BITS)
outa[noparse][[/noparse]DATA] := TX_BYTE >> (BITS-1) ' Set output
TX_BYTE := TX_BYTE << 1 ' Shift value right
!outa[noparse][[/noparse]CLK] ' cycle clock
waitcnt(1000 + cnt) ' delay
outa[noparse][[/noparse]DATA]~ ' Set data to low
outa[noparse][[/noparse]CLK]~ ' Set clk to low
·Give me some slack, please.. I have programmed SX controllers for five years but the prop just blows my mind :-)
PUB SEROUT (TX_BYTE)··································· ' MSB FIRST SERIAL OUT ROUTINE
· outa[noparse][[/noparse]CS1B]:=0········································ ' SET THE CS1B PIN LOW FOR WRITE OP.
· REPEAT (BITS)·······························································
····· outa[noparse][[/noparse]DATA] := TX_BYTE >> (BITS-1)·················· ' Set output··········
····· TX_BYTE := TX_BYTE << 1···························· ' Shift value right···
····· outa[noparse][[/noparse]CLK]:=1······································· ' SET CLOCK HIGH - TO CLOCK DATA OUT
····· outa[noparse][[/noparse]CLK]:=0······································· ' SET CLOCK LOW···························································
····· waitcnt(1000 + cnt)································ ' delay···············
· outa[noparse][[/noparse]DATA]:=0········································ ' Set data to low
· outa[noparse][[/noparse]CLK]:=0········································· ' Set clk to low
· outa[noparse][[/noparse]CS1B]:=1········································ ' SET THE CS1B PIN HIGH FOR IDLE OP.
First of all... thanks for posting the question. Second... which lcd are you looking at?
I have never looked at the serial routines... it's on my list[noparse]:)[/noparse]
So, if there is a subtle problem here... it's beyond me.
But... I have a question about timing.
You appear to be using a waitcnt to stall the main until the subroutines executes... so that the next instruction doesn't get executed before the current call has had a chance to return. Is that almost correct?
(If so... I was told not to do that!!!)
Rich
It´a Displaytech LCD panel from RS Components. They are based on the S6B1713 (KS0713) COG controller.
I saw my mistake regarding the delays and now the routine itself is running. It did stall because of the delays I made, but I still can´t get the LCD up and running. I will check my connections and check the pulses with my FlukeMeter tonight.
Thanks for the tip regarding the delays.
Jan
Jan
