Interfacing with 2.5V logic?
I've tried searching the forum for this, but only found how to interface with 5V logic. My question is, sine the Props logic high threshold is Vdd/2 (1.65V, from p16 of the Prop manual)- will it detect logic high from devices running at 2.5V?
From what I've found so far, 2.5V devices have a high signal threshold between 1.7 and 2V, but I don't know how much of a standard that is?
cheers- Scott
cheers- Scott
Paul Baker
Parallax Forums - If you're ready to learn, we're ready to help.
Paul Baker
As Prop Vih = 0.6*3.3 = 1.98, and typical 2.5V logic has a Voh of 2.3V for lightly loaded signal (from 74LCX data sheet)
To be sure you really would need the switching characteristics for the device.
If in doubt this same circuit (from SparkFun) would work (2.5V device on left, 3.3 on right)
http://www.sparkfun.com/tutorial/Sensor-Interfacing/ST-5.jpg
