Are you building a RIMS system for brewing? If so, I have built one that works pretty well and would be happy to share any information about it. Shoot me an email off list.
Jonathan
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
otherwise you may have to use a solenoid( or other device)·to pinch this food grade tubing
http://rswww.com/cgi-bin/bv/rswww/searchBrowseAction.do?obs=sObs&name=SiteStandard&No=0&N=0&Ntk=I18NAll&Ntt=solenoid%20food%20grade&Nty=1&D=solenoid%20food%20grade&Ntx=mode%20matchpartial&Dx=mode%20matchpartial&callingPage=/jsp/search/search.jsp&BV_SessionID=@@@@0601667602.1181689765@@@@&BV_EngineID=ccciaddlegimghkcefeceeldgkidhgj.0&cacheID=ukie&Nr=avl:uk
not sure if you are able to order from outside the UK or not you'd have to get in contact with them.
or use a motor operated ball valve SS with tefflon seats and flush out with
alcohol 100%.
Jonathan
