TV_text and the spin stamp
Gent's
I have just received my spin stamp and board of education. I have made the corrections to the spin code, but I cannot see any text ! I have a blue screen though.
I added _clkmode=xtal1+pll8
·········· _xinfreq=10_000_000
P0 resistor 1.2 k
P1 resistor 560
P2 resistor 270
Has anybody had this problem ?
I am new to spin and am trying to understand the code.
I have attached the spin code I am useing.
P0 resistor 1.2 k
P1 resistor 560
P2 resistor 270
Paul Baker
O.K. now I feel real stupid.
I will try that, I should have completed all of the PEK labs first ! Objects are my next chapter.
Thanks again
Rob7
It work's perfectly on a regular TV set!
Almost looks like an overdriven signal (>1V P-P) or something. I included a pic.
Paul Baker
I read Paul Baker's reply. I downloaded the TV Text Demo and that works perfect on my Proto Board. (Note: I scratch built the circuitry to morph my Proto board into a Demo board.)
Any ideas?
Disregard the image I attached.·The capture didn't·work. What I get is a really bright, washed out·text and background, other times blue or black.
Paul Baker
The TV Text Demo works fine on composite inputs to a regular TV and my ATI PC TV card.
Paul Baker
I'm following the The WebPM-v1.01.pdf book. Chapter 3.· See pic.
Thanks for the help!
Paul Baker
Paul Baker
Not to get off the subject with W9MAS, I got it working ! Great job. Thanks for the help.
W9MAS, hope you get yours working.
I attached the code for the Spin stamp, TV terminal and TV text.
Rob7
Post Edited (Rob7) : 6/12/2007 6:30:04 AM GMT
pin 0 1.2k
pin 1 560
pin 2 270
Have fun !
Rob7
The Graphics_Pallette and Graphics_Demo produce the same negative results. Through experimentation, I can get a better display by varying the resistor value on pin 12 to something lower.
I need to play with the program and learn how it works, then make it simple. To a newbie, simple is best. I am still learning how spin code works.
Rob7
Paul Baker
Substitued trimmers for resistor network and adjusted for best picture quality. TV PC card is much more sensitive to variations in sync pulse amplitude than conventional television.
