USB in software — Parallax Forums
USB in software
LeonLeon Posts: 7,620
edited 2007-06-10 15:33 in Propeller 1
Some time ago someone implemented a USB interface on an Atmel ATtiny2313 AVR running at 12 MHz:
http://www.obdev.at/products/avrusb/index.html
It should be feasible to do the same sort of thing with the Propeller. I'm not volunteering, though.
Leon
    edited 2007-04-16 12:49
    Ok, I'll come in on this as this is one of the things that I will be implementing as soon as I get "a round tuit". Yes, I remember the Atmel implementation and even though it ate the chip resources it worked, albeit as a simple slow-speed slave. This is fine as there is still a lot that can be done at 1.5Mbps and although it may eat up a whole cpu this is only one cog on the Propeller. So it would be rather nice to have a USB object that could also host USB HID devices as keyboards and mice are certainly all going that way.
    I mainly want to emulate HID and UART class devices but the nextgen Prop will be that much faster I would think it would be possible to easily run 12Mbps. At that speed it might even be possible to emulate a 10Mbps ethernet device at some level which almost any 10/100 ethernet interface will be happy with.
    *Peter*
  • JoannaKJoannaK Posts: 44
    edited 2007-06-10 02:16
    Sorry for a late reply.. I have been away from propeller forums couple months..
    I have been having this idea of making USB low level drivers with Propeller assembly, and was considering it (low speed mouse/keyboard type) to be my MSc thesis material, but I'm not sure if it'll be possible. I'm now in middle of finalising my BSc and I need to look out what can be done with local Uni... They aren't really too interested about Embedded like stuff.
    For timing.. I had some preliminary code segments (untested) for 1.5MBps read/write written, it needs a bit higher clock than usually (IIRC 6 MHz xtal with 16* PLL) to work.
    Edit.. sorry.. I think 6MHz oscillator and 16X pll woul be ok.. That's 96Mhz clock => 24MIps => 16 instructions/each bit in low speed Usb bus.
    Post Edited (JoannaK) : 6/11/2007 2:06:57 AM GMT
  • inakiinaki Posts: 262
    edited 2007-06-10 15:09
    Take a look at this one, althought it is for AVR too:
    http://www.elektor.de/Default.aspx?tabid=27&art=5551005&PN=On
  • TransistorToasterTransistorToaster Posts: 149
    Cool! It's also based on Leon's link.
