Troubleshooting Basic Stamp Board I code to Homework Board
I tried to run the below code in my homework board and got the following error:
lable is missing ';'
SYMBOL in SYMBOL Servo_pin = 0 is highlighted
I've tried running in Stamp 2.0 and still did not work.
The above code was taken from RoboSheep project:
http://www.2robots.com/2006/10/21/robosheep/
Thanks for helping.
‘ {$STAMP BS1}
‘ {$PBASIC 1.0}
SYMBOL Temp = W0
SYMBOL Temp2 = W1
SYMBOL Rand = W2
SYMBOL RSensor = PIN1
SYMBOL LSensor = PIN2
Init:
Rand = 55
Main:
RANDOM Rand
Rand = Rand // 8
Rand = Rand + 8
PAUSE 2300
Temp = RSensor
Temp2 = LSensor
DEBUG Temp, Temp2, ” “
IF Temp = Temp2 THEN Center
IF Temp > Temp2 THEN Right
GOTO Left
Right:
DEBUG “Right”
FOR temp = 0 TO Rand
PULSOUT Servo_pin,120
PAUSE 30
NEXT
GOTO Main
Left:
DEBUG “Left”
PULSOUT Servo_pin,190
PAUSE 30
NEXT
GOTO Main
Center:
‘FOR temp = 0 TO 2
‘PULSOUT Servo_pin,150
‘PAUSE 20
‘NEXT
GOTO Main
Thanks for helping.
- Stephen
Chris Savage
Parallax Tech Support
I didn't see the SYMBOL syntax in the PBASIC sytax guide. I wish there is some type of tool that can convert SB I to SB II code standard...
Franklin,
The error happens in line 4.
SYMBOL·Servo_pin·=·0
Joel
That is listed un Memory and Variables under Defining Variables. This is different for the BS2, which uses the format:
Servo_pin VAR Byte
Or
Servo_pin CON 0 (If you’re defining a constant)
Chris Savage
Basic Stamp 1 Code:
'{$STAMP BS1} '{$PBASIC 1.0} SYMBOL Temp = W0 SYMBOL Temp2 = W1 SYMBOL Rand = W2 SYMBOL RSensor = PIN1 SYMBOL LSensor = PIN2Would look like this in BSBII:
'{$STAMP BS2} '{$PBASIC 2.0} Temp VAR Word Temp2 VAR Word Rand VAR Word RSensor VAR IN1 LSensor VAR IN2Am I getting wamer with this?
Everything looks good. If you were using PBASIC 2.5 you could set up the I/O declarations as follows:
RSensor PIN 1
LSensor PIN 2
Take care.
Chris Savage
