Professional Development Board alternative
Do you have any suggestions for an alternative to the Parallax pro. development board? I don't think I can shell out the $150 for it (I can personally, but my parents won't approve)...
I currently have the SX Tech board, but the breadboard space simply isn't big enough and it's limited on features. I think it's great for starting projects (when they're small in the beginning) and programming the SX, but I need something bigger. I have a huge breadboard, but having all the 'amenities' that the dev. board comes with is much preferred.
I might be able to convince my parents to let me buy it this summer when I have a job, but thats a maybe. I just spent $150 on the SX stuff I have now, so another $150 on top of that isn't very justifiable.
Any suggestions? I'm just looking for something reusable with a large prototyping area (extra stuff like displays are always welcome)
Dan
Dan
Russ
take a protoboard $10·... solder in some sip pins in the holes for the pinouts and the vss and vdd on the protoboard. get a large cheap breadboard , use doublesided tape to stick the proto board to the breadboad... and use jumpers to make your circuts.
the advantage to this is you can get another protoboard and copy your compleated, tested circut to the new protoboard, program with the sx-tech dongle thingy , and your off !
works good for me, and if you get a easy to solder, power regulators already on, board.
dan
This is the type of setup Sawmiller is talking about. You should be able to replace the "standard" sized bread board with a larger one, just let it hang off the edges of the proto board.
Then again, you could still try selling mom and dad on the pro development board. Point out all the neat stuff: Real Time Clock, Serial Driver, LEDs, switches, etc. There isn't a lot you can't at least start development and testing work with one of these boards. Think of all the trips they'd save to the local radio shack for misc small stuff like switches and LEDs.
John R.
Click here to see my Nomad Build Log
I have a Parallax NX1000 (I think it's the NX1000/24), they don't sell them anymore, but it's yours if you want it.
It doesn't have a socket for the SX28, but you can just plug the SX28 into the breadboard and connect a 4 pin header to program it (don't forget the 10K resistor from /MCLR to +5V).
Send me a private message if you want it.
I can't find the datasheet for it on the Parallax website, but here is a picture of it (not a very good picture of the NX1000 though) http://forums.parallax.com/attachment.php?attachmentid=40096
[noparse][[/noparse]edit] I guess this is the datasheet for it http://www.parallax.com/dl/docs/prod/boards/28137.pdf
Bean.
“The United States is a nation of laws -· poorly written and randomly enforced.” - Frank Zappa
www.hittconsulting.com
Post Edited (Bean (Hitt Consulting)) : 6/7/2007 4:38:35 PM GMT
Did you receive the NX1000 yet ?
Bean.
But yes, I did get it Monday it it works great. Thank you so much. I appreciate your generosity!
-Dan
Bean.
tr
Parallax gave them away during a housecleaning a few years ago, but I never would up doing anything with them, so you can have them if you want (if I can still find them in the garage).
If you're interested, let me know and I'll look for them.
Tom Talbot
New Market, MD, USA
http://www.parallax.com/Store/Microcontrollers/BASICStampDevelopmentBoards/tabid/137/ProductID/123/List/0/Default.aspx?SortField=ProductName,ProductName
Jim
