bug report: missing chip connection crashes my computer — Parallax Forums
edited 2007-08-08 05:42 in Propeller 1
I have noticed that if there is no serial port/USB connection to the chip and I try to run either the Identify Hardware command or the download to EEPROM command (by mistake) in the propeller software it freezes the program and then my computer if I try to force quit.
FYI I am running windows XP on a 2GHz pentium with 1.5GB of RAM.
-heather
    edited 2007-06-06 00:53
    Heather, you will need a prop plug to interface between·40 pin dip prop chip and a 4 pin header to plug into bread-board and the prop plug . Prop plug offers a USB connection between prop plug and computer. All wiring diagrams are availabale @www.parallax.com. If you have a spin stamp you'll need basicily the same stuff·. www.parallax.com.· The sales Department can help alot.· Good luck!!!!··· Dave············
    Fix it if ain't broke·
    D Rat
    Dave Ratcliff· N6YEE
    Post Edited (ratronic) : 6/6/2007 1:00:51 AM GMT
  • edited 2007-06-06 01:10
    yes, i have the prop plug. I was just mentioning that if I forget to plug my chip in and accidentally attempt to use the propeller software to either download to an EEPROM or identify the chip the program crashes. In other words it should just say "no chip available" or something along those lines.
    -heather
  • RinksCustomsRinksCustoms Posts: 531
    edited 2007-06-06 01:40
    software engineers are such - engineers. they meet a challenge, like making it real easy to program a microcontroller (try to prog a Zilog MCU setup, only $40! LMAO), they write programs under certain asumtions, like having everything connected and functioning properly.
    other thoughts: 1.5GB ram? whle most mobo's will tolerate mismatched ram size and XP doesn't really have a problem w/it either, it's not really the best idea to have a stick of 1GB mixed w/a stick of 512MB, could lead to instabilities, trust me...
    Definetly a E3 (Electronics Engineer Extrodinare!)
    "I laugh in the face of imposible,... not because i know it all, ... but because I don't know well enough!"
  • CJCJ Posts: 470
    edited 2007-06-06 01:54
    do you have any built in com ports?, that is the only thing I can think of is if there isn't an onboard port and no attached usb one,
    RinksCustoms, 1.5 could very easily be made up of 2 512's and 2 256's balanced on the channels
    Parallax Forums - If you're ready to learn, we're ready to help.
    edited 2007-06-06 02:09
    good point CJ, didn't think of the 4ch mobo's, was thinking of dual ch, dual tech (DDR/DDR2) mobo's which only support one tech or the other, my bad, i appologize.
  • edited 2007-06-06 02:36
    i do have a built in serial port actually... is that a problem?
  • CJCJ Posts: 470
    edited 2007-06-06 02:58
    not a problem, just trying to think of anything out of the ordinary that could adversely affect the prop tool
    have you tried rebooting?
    maybe reinstall the prop tool?
    edited 2007-08-06 21:13
    Heather do you have a bluetooth module on your computer?
    Paul Baker
  • edited 2007-08-06 21:20
    yes...
    edited 2007-08-06 21:21
    Try disabling the module and see if that fixes your problem.
    Paul Baker
  • SkogsgurraSkogsgurra Posts: 231
    edited 2007-08-07 10:23
    Thanks!
    I have had that problem when forgot to close Hyperterminal before going to IDE. I guess I am that sort of guy that just restarts without complaining. Been at it too many years - got used to quirks.
    Anyhow. I killed Blutooth and now I have no problems at all. Ok then, some, but not with COM5 and COM6.
    edited 2007-08-07 16:46
    We've had enough people complain about this that we are going to look into some solution for this, right now we are leaning towards a black-list.
    Paul Baker
  • MightorMightor Posts: 338
    edited 2007-08-07 17:56
    Paul,
    As some others have already suggested, a much more flexible way would be to allow people to chose the ports they wish to have scanned by the Prop Tool if the automatic scan causes their system to lock up. I really don't think that trying to cater for all the 1000's of device permutations out there is going to work. A blacklist doesn't fix the underlying problem in a fool-proof manner and I can promise you will have the same problem again in a month from when you release the first list when a new device comes out. The blacklist is fine, but please allow for a manual override as well, at least that will cater for the time between blacklist updates so people can use their computer without ripping all sorts of devices out when they want to use their Prop.
    Gr,
    Mightor
    | What the world needs is more geniuses with humility, there are so few of us left.
    | "Wait...if that was a compliment, why is my fist of death tingling?"
    | - Alice from Dilbert
    edited 2007-08-07 18:01
    Mightor, you're misunderstanding how we would implement the black-list, it would be a user settable list of COM ports not to check, if you place all COM ports besides one in the list it becomes a direct select list.
    Paul Baker
  • Tom WyckoffTom Wyckoff Posts: 26
    edited 2007-08-07 21:03
    RinksCustoms said...
    I do that fairly often, the prop tool just says "No propeller chip found........" That's a small pop-up window that may be hidden behind the main window and stopping you from shutting down the prop tool.
    I have a 512 meg stick and a one gig stick in this box (2 ghz celeron) and it's stable as a rock.
  • AribaAriba Posts: 2,693
    edited 2007-08-07 22:38
    Paul Baker said...
    we would implement the black-list... ...if you place all COM ports besides one in the list it becomes a direct select list
    Why this complicated way instead of the easy one: let us choose the COM port that we want to use ?
    I really don't like this automatic searching feature of the IDE. Imagine all IDEs would do that, then it were impossible to use more than one chip in parallel (if you program an AVR the Propeller is resetted, if you program the Propeller the AVR is resetted...).
    The same happens if you try to work with more than one Propeller and the IDE!
    The automatic searching can be usefull for absolute beginners, but after a short time also they know the number of the used COM port. So my suggestions:
    - Automatic searching only if you press F7 (identify hardware), and then store the found COM number.
    - F10, F11 uses the stored COM number.
    - Shift-F10, Shift-F11 ask first for the COM number to use (and store it).
    A black-list not solves the problem with more than 1 Propeller, and you have to edit this list every time you install new hardware that makes problems. A White-List would be better, but it must be possible to choose which list-entry is used first for searching.
    Cheers
    Andy
  • Chad GeorgeChad George Posts: 138
    edited 2007-08-07 23:02
    Paul,
    I'm glad to hear that something is being worked on. I would agree with Ariba that I'd prefer a white list of Comm ports that the IDE is allowed to scan. That way the "default" white list could include say every port from 1-20 so the newbie's won't really know any differ. If the port is on the whitelist and enumerated as available then the IDE does it's autoscan. Advanced users could then use it to select specific ports and even the order that ports are scanned in.
    On the other hand, if you're going to use a configuration file it seems pretty trivial to allow it to be either a blacklist or a whitelist. I don't see why it has to be one way or the other. The blacklist is the most consistent with current functionality (so I understand its appeal), but the whitelist fixes the problem 100%.
    Chad
    edited 2007-08-07 23:03
    We haven't decided which method we will use yet, but we are not be getting rid of the auto-search.·I·will·pass forward peoples comments, but I can't debate the various methods because I am not the decision maker, I'm only communicating what has been discussed.
    Paul Baker
    edited 2007-08-08 04:03
    Paul Baker (Parallax) said...
    We haven't decided which method we will use yet, but we are not be getting rid of the auto-search. I will pass forward peoples comments, but I can't debate the various methods because I am not the decision maker, I'm only communicating what has been discussed.
    Paul,
    I did misunderstand your concept of the blacklist. I'm sorry about that. I was under the impression that you meant you would blacklist the actual device IDs (either by USB or PCI ID) which would seem a little convoluted.
    The black list is nice, but it would mean the user would have to revisit it when they add a new device like an mp3 player or a pda or something like that. Plus, as mentioned by other peeps, some software packages install virtual com ports for redirects and what have you without you knowing it. A combo of both a whitelist AND blacklist would make *everyone* happy (well, *almost* everyone). You don't need to get rid of the auto scan function, just make it something you can disable and override. For people with a couple of devices that are known to cause insta-death for the computer when the Prop tool tickles them, there is the blacklist. For others who have multiple props, for example, and only want to program a particular one, there is the whitelist system.
    Gr,
    Mightor
    Paul,
    I would much prefer a whitelist, with an optional discovery process to scan for new devices. Devices that are found could be selected (or not) for inclusion in the whitelist. Now that the FT232R has become ubiquitous, each with its own serial number — hence, each demanding its own com port — a finite whitelist seems much more manageable than an ever-expanding blacklist.
    But beyond that, it would be nice just to specify, for a given job, which single port to use. I don't necessarily want all the devices on my whitelist to be reset every time I upload code. A simple cluster of tiny radio buttons in the taskbar, representing the whitelist, could handle this with grace and ease.
