Cutting Circuit Boards
I'm putting components into a circuit board, and need to reduce the size. The components only use up the bottom corner of the board. What is the best way to cleanly cut away the excess circuit board.
I don't have that many power tools... just a drill and a dremel. Can I do it with this stuff?
Thanks!
Thanks!
Also, when I use the dremel w/ the standard cutting wheels, they sometimes break apart and fly off. Is this common? Should I just try to stay out of the "line of fire"?
I cut my PCB's with an 8" band saw $80 home depot. but I have cut many things with my dremel in the past. highly recommended.
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
Don't visit my new website...
If you plan to cut boards often I would recommend getting one (harbor freight sells and 8" one).
Bean.
“The United States is a nation of laws -· poorly written and randomly enforced.” - Frank Zappa
www.hittconsulting.com
You don't have to cut all the way through.· In cutting board material (to make smaller boards like), I get it down so that it's very thin and then I can break it free and then smooth·everything out with a file.
The little red guys are brittle, so I use them mostly to·buzz·away pads and traces.· There's a coarse wheel that I think works best for cutting boards.·
I wear a mask, too, to avoid that fiberglas dust.
It will not fly apart, and will last forever cutting circuit boards..
Another good way to cut a board is by using a scroll saw with a fine blade,
and a straight edge jig/stop to guide the board against.
While a mill is certainly a "technically superior" alternative, from a practical standpoint, getting a straight line and ease of use/time involved would all point to a cut off wheel when working "free hand".
I would agree that a diamond wheel would not be the best choice, but for small volume, the clogging might not be too much of a problem.
The thin red discs are not really meant for this type of application, and when applied this way, are prone to breaking/shattering unless you are extremely patient. There are thicker wheels available, the ones I'm thinking of look like they are "fiberglass reinforced".
John R.
Click here to see my Nomad Build Log
Post Edited (John R.) : 6/7/2007 12:13:00 PM GMT
i did a few projects at home with an endmill type tool and it worked out pretty well for straight lines.. i did a biohazard sign out of the side of a computer case and i did a lot of case mods for xboxes. in plastic its supprisingly easy to freehand a straight line. and i did finish it off with a little fime grade sand paper to give it a really clean look. id suggest just increasing the arsonel of tooling to include a 'drywall cutter' or endmill..
The primary business was manufacturing carbon brushes (i.e. for motors and generators).
I miss having access to that stuff :-(
I guess what I was really trying to say above was that some people may find using the "drywall cutter" or "end mill" type bit a little harder to use cutting a sheet of material. Others may not. I probably shouldn't have been quite so "this is the way to do it" and more "you may find this works easier".
And in case it didn't come out right, if I had access to that shop, I would probably mill the boards (and use one of the "hybrid" machines to drill the holes too).
John R.
