Temperature Increase in DS1620
Does the temperature reading of the DS1620 suppose to constantly rise if you allow it to continous retrieve the measurements?· The readings begins perfect, but begin to read wrong.· Temp starts at 72 degrees F, then in 20 mins the temp reads 80-82 degrees.· Is this due to power of calculating within the DS1620.· Is this heat added to the readings.·
Chris Savage
Parallax Tech Support
I am getting a temperature somewhat offset with my DS1620. It gives me 25C, however other mercury and digital thermometers around say 22C. Do any of you have similar findings? Please send me a private message and carbon copy it on the board.
The internal power dissipation of the DS1620 when it is operating in "continuous" mode is around 5 milliwatts, and assuming Tja of 100 degC per watt for DIP package, that could raise the die temperature by about 0.5 degrees above ambient. To eliminate that possibility, put the chip in single shot mode and query it only once every few seconds. It goes into a microwatt sleep mode between readings.
Other things: No loads on the thermostat outputs of the DS1620 that would make it dissipate power, and similarly no pullup or pulldown resistor on the data line.
Finally, are you sure of the calibration of the other sensors? Are they ASTM certified?
It is usually not good form to cross post solicit responses on three fora at once. A processor-neutral question like this is usually best posed in the Sandbox forum.
Tracy Allen
www.emesystems.com
Post Edited (Tracy Allen) : 5/30/2007 4:48:39 AM GMT
Chris Savage
I am reading room temperature, the other thermometers are not at all connected to my breadboard. Also, another sensor is me, and what I feel that the temperature is.
Ok, I'll experiment with different polling rates. I already have it in one shot mode.
I let the thermostat output lines unused. I do have a resistor on the data line, but it is in series, so no heat generation.
I thought about that one. You see, last time nobody at all responded. Or the ones that continued on the threads ignored my question. Probably not the best excuse. Not all people read all the sections of the board.
