In , out and cmp — Parallax Forums
In , out and cmp
Brian_BBrian_B Posts: 844
edited 2007-06-01 09:17 in Propeller 1
I'm trying to read 3 switches on pins 0,1,2 and display results on pins 4,5,6· . any suggestions on my code ?
Thank's Brian
www.truckwiz.com
·"Imagination is more important than knowledge..." ·· Albert Einstein
http://www.diycalculator.com/subroutines.shtml· My favorite website ( Bet you can't guess why)
    edited 2007-05-31 02:13
    Your "cmp" use a literal source (#test1) which compares against the address of test1. Use "cmp temp,test1" to compare against the contents of test1.
  • Brian_BBrian_B Posts: 844
    edited 2007-05-31 02:23
    Mike,
    ·Changed it and it's still not working.
    Thank's Brian
    www.truckwiz.com
    edited 2007-05-31 02:55
    How do you have the switches and LEDs connected?
    The way the code is written, one and only one switch (I/O pins 0-2) at a time should be connected to Vdd and the others have a pulldown.
    The LEDs (I/O pins 3-5) should be connected from an I/O pin through a series resistor to ground. 3 LEDs on = pin 0 on, 2 LEDs (pins 3-4) on = pin 1 on, 1 LED (pin 3) on = pin2 on
    edited 2007-05-31 03:08
    Mike,
    This program works fine for reading a pin and displaying results.
    Thank's Brian
    www.truckwiz.com
  • JamesxJamesx Posts: 132
    edited 2007-05-31 03:44
    Brian:
    Clever code. Very nice!
    Jim C
    edited 2007-05-31 11:28
    Jim c,
    ·Thanks
    Mike ,
    ·Heres how my LEDS and pushbottons are hooked up , still trying to get the CMP code to work. Also I am trying to light up 1 led ,2 leds and 3 leds .
    Thank's Brian
    www.truckwiz.com
    Post Edited (Brian Beckius) : 5/31/2007 11:56:47 AM GMT
  • Graham StablerGraham Stabler Posts: 2,510
    edited 2007-05-31 12:59
    You probably need to mask test before you do the compare because if any of the other propeller pins have a one on them then time and test1 will not equal.
    :loop   mov   time,ina
              and    time,mask            'mask
              cmp  time,test1        wz
    if_z     jmp   #:ans1
    mask    long  %000111
    edited 2007-05-31 15:52
    Works perfect , thanks Graham
    ·Heres another chunk of code thats giving me grief· , this one is to suppose to inca djnz·the 6 leds and then start over .·But instead it·turns all leds on and waits 10 minutes to start . Is this a mask issue also ?
    Thank's Brian
    www.truckwiz.com
    Post Edited (Brian Beckius) : 6/1/2007 2:33:23 AM GMT
    edited 2007-05-31 19:07
    Well I don't know what inca is but I think you will find the problem is that you are adding two small an amount to time before the initial waitcnt.
    So it loads outa with 111111000 and then gets the waitcnt where it misses the time and then sits until it comes around again. So you need to add delay to time not 9.
    And rather than doing
    mov outa,testpin
    you might consider doing
    or outa, testpin
    That way if you are doing something with any of the other pins in a different part of the code you won't effect them because remember 111111000 is really:
    0000000000000000000000111111000
    That may be the point you are missing and why you are not sure when to use a mask.
    Graham
    edited 2007-05-31 20:00
    Graham ,
    I meant djnz not inca . Changed 9 to 255 , works great
    Thank's Brian
    www.truckwiz.com
    edited 2007-05-31 20:19
    You must have ancient south American societies on your mind [noparse]:)[/noparse]
    edited 2007-06-01 01:10
    Graham,
    Just so I have my brain fully wraped around waitcnt.
    · CLOCK
    12_000_012
    12_000_013······' Mov time,cnt
    12_000_014······ 'add· time,#9
    12_000_015······ 1
    12_000_016······ 2
    12_000_019······ 3
    12_000_020······ 4.....8
    12_000_025···· 9·······' stop what your doing and wait 6_000_000 clock ticks
    18_000_025······ ' quit sitting around and get moving
    delay···· long····· 6_000_000
    So by adding 9 to the time ,you need to make sure that the instructions your trying to exacute don't take longer than 9 clock ticks ?
    Thank's Brian
    www.truckwiz.com
    Post Edited (Brian Beckius) : 6/1/2007 1:30:32 AM GMT
    edited 2007-06-01 01:58
    Basically yes remembering that each instruction takes 4 clock cycles so you would only have time for 2 and a bit instructions.
    Graham
    edited 2007-06-01 03:56
    Cool !!!· (so 255 was a little over kill ?)
    Thank's Brian
    www.truckwiz.com
    Probably and a randomly precise value to boot [noparse]:)[/noparse]
