AX-12 with the Propeller
· Has any one used this actuator with the prop or stamps before?· thinking of doing a servo upgrade but not sure this actuator can be used with out the cm-5 unit because you have to set the "actuator ID".·· Would like to make sure before I spend the $$$...
Does this lib file give enough info for a direct prop setup?· There PIC is only 40Mhz but the·serial port is·600k with a·hardware interrupt.
Post Edited (KC8DKT) : 5/30/2007 7:49:20 AM GMT
Send me a message·with your email address.
They look good on the data sheets but no one seems to use them with out that dumb cm-5 box.
EDIT: I found the Old Thread about this.
Post Edited (Bergamot) : 5/30/2007 9:14:39 PM GMT
For now, if you want to check the code please send me your email to my Parallax account and I will send the source code.
