Senior Project
Hi. My name is Matt.· I will be graduating in August and I have just begun my project.· I am·using the·basic stamp homework borad to control·a bathroom ventilation fan with the sht11 temp./humidity sensor and the flexiforce sensor.· I began with the sht11 and I am having trouble with the readings.· I used the code from the parallx webpage but my temp. and humidity readings are off the charts.· If anyone has completed a project similar to this or can help me with the sht11 I would surely appreciate it.· I attached the code for the sht11 that I used.
http://www.parallax.com/dl/docs/prod/acc/SensirionDocs.pdf
Don't wait till the last minute, whatever you do.
