pressure transducer
···· Hi I am working with the BS2 to use the voltage output on the tranducer I am charging a rctime circuit and measuring the time and taking the value of the time to refer to my pressure, but I am discovering that there is a curve in the output of the transducer, example converting the time to pressure value at virtually 100psi is different then at 40psi, do I need a lookup table? or how would you go about it?
Thanks for your reply: Toby
- Stephen
Tracy Allen
www.emesystems.com
What are you using the pressure transducer for are you trying to have it readout on an LCD I dont understand why the curve matters?
