Fuzzy logic positionning system
Hi,
Does anybody has already implemented a fuzzy logic positionning system with a BS2? Is it an appropriate regulation system for a DC motor using a incremental encoder as feedback position?
Fr
Fr
- Stephen
http://forums.parallax.com/forums/default.aspx?f=5&m=191601
Instead of using a PID (which will work, for sure), I was wondering if using fuzzy logic could be interesting... and fun! I read articles about fuzzy logic, years ago. But all examples show temperature regulation, with driven heat source. Is a closed-loop system controling a position similar? Or are there fundamental differences, which make fuzzy logic inappropriate in this case?
Fr
So I guess you can use Fuzzy logic in same way. But I guess Fuzzy Logic is easier to implment in BS2 (than NN). Its matter of writing a bunch of IF loops. But u may run into trouble of floating numbers while dividing the range into vaious membership functions.
And yes implementing a fuzzy controller is quite appropriate in any control problem. The only difficulty in fuzzy control is to better understand the system u r designing, the expected range of input(s) (position as i understand, may be velocity additionally), then taking help of Matlab fuzzy logic toolbox to decide the control strategy and implementing it in hardware.
I neve implemented fuzzy in hardware but in simulations what i found is fuzzy controllers r a bit tough to design but efficient to system disturbances.
Best of Luck
Suman Sadhu
Post Edited (Suman) : 5/28/2007 8:53:18 AM GMT
Fr
www.elecdesign.com/Articles/Index.cfm?ArticleID=4915
Or go to the Electronic Design magazine web site...
www.elecdesign.com/Search/Index.cfm
and type this into the search:
What's All This Fuzzy Logic Stuff, Anyhow?
Or Bob's home page at National Semi...
www.national.com/rap/
Tracy Allen
www.emesystems.com
Fr
