starting program
I would like to start the program that is on my stamp homework board by turning on a power switch.
How can I do that. The reset button on the board is not accessable and I will not be connected to a computer. I can wire a button that is accessable.
Thanks.
JG
Thanks.
JG
- Stephen
I thought that was the way it was supposed to do, but it doesn't. It has a series of light that are supposed to go on and off but they don't until I push the button on the unit.
Ideas?· Could it be a software deal?
JG
- Stephen
Here it is. Very simple test program. It won't do the counting until I push the button.
JG
' HIGH_LOW.BS2
' Simple test program to test light sequence.
' {$STAMP BS2}
n VAR···· Word
· PAUSE 250
· main:
· FOR n = 1 TO 8
· HIGH n
· PAUSE 500
· LOW n
· PAUSE 500
· HIGH n
· PAUSE 500
· LOW n
· PAUSE 500
· NEXT
· GOTO main
· END
Is the green "Running" LED lit when you power up the Stamp board, or only after you press the RESET button? I presume the button you're speaking about is the RESET button on the Homework Board?
Just a passing comment - there is no reason for your variable "n" to be a WORD sized variable. Since it can only contain the values 1-8, making it a BYTE or NIB would be adequate. Additionally, I trust you realize the pin ports are numbered 0-15 and not 1-16.
Bruce Bates
I do understand the pin numbering and the variable size. Thanks.
Ill have to run it again to see if the status on the light.
JG
Ill try that.
JG
