FullDuplexSerial Stop Bits — Parallax Forums
TomSTomS Posts: 128
edited 2007-05-26 20:52 in Propeller 1
I'm using the Parallax Full Duplex Serial object and have noticed that when transmitting, it uses two stop bits. I would like to modify the code to send only one stop bit but of course I don't know assembly programming. Anybody have an answer for me (other than learning assembly)?
All help appreciated
Tom
    edited 2007-05-26 00:30
    Hi Tom,
    Usually it's not a problem if 2 stop bits are transmitted as most applications are not trying to push the limits of a already limited communications medium. The FullDuplex object does not actually send 2 stop bits but it effectively does so because it transmits an idle bit before the start bit. The code snippet around line 252 (comments added) shows that a stop bit is appended with #$100 and then room is made for a start bit and a padding bit by shifting left 2 bits. The data is transmitted lsb first so the first bit is actually an idle bit.
                            or      txdata,#$100          'Add a stop bit after the 8 data bits
                            shl     txdata,#2               'make room for a start bit plus a padding bit
                            or      txdata,#1               'force the padding bit to an idle/stop bit
                            mov     txbits,#11            'count 8 data + 1 stop + 1 start + 1 idle/stop
                            mov     txcnt,cnt
    I haven't tried it but you could try this.
                            shl     txdata,#1               'make room for a start bit plus a padding bit
                            mov     txbits,#10            'count 8 data + 1 stop + 1 start
                            mov     txcnt,cnt
    *Peter*
  • TomSTomS Posts: 128
    edited 2007-05-26 00:37
    Thanks Peter,
    I'll give it a try.
    Tom
    edited 2007-05-26 12:18
    It Works!
    Thanks Again Peter. I'm not making the change for speed but for compatability.
    Tom
    edited 2007-05-26 13:49
    From a compatibility standpoint, it shouldn't matter. To any receiver attached to the Propeller, a serial stream with 2 stop bits is indistinguishable from a serial stream with 1 stop bit and a little bit of internal delay between characters transmitted due to computation or other I/O. The side of FullDuplexSerial dealing with receiving an external serial stream only needs one stop bit, doesn't even check for that, and will accept essentially any delay between characters.
    Thanks for the good info Mike. I'm replacing a commercial device that uses one stop bit with my propeller driven device and I want the change to my device to be totally transparent. You're right, it probably wouldn't make any difference though.
    Tom
