hi!!! i would like to know how i could make a graph be display·of an ·incomin signal from any pin...?????? the signal could be audio, pulse train etc. if someone knows please let me know
We need a bit more info. How do you want to display the graph? On the television, using the Propeller's video capability? On the computer, by uploading data? Or some other method?
If you want to display a digital signal (low or high only) then you can record it directly. But if you have an analog signal, you will need an analog to digital converter chip (ADC). Someone started a thread in this forum a few months ago about how to use an ADC with the prop, and there is a Spin object for that, so it is doable. Just be aware that it will take more work than getting a digital signal.
There is no graphing object... but that is a great suggestion.
My guess is that if you are patient... someone will roll it into an object.
There IS an object that will allow you to export to an Excel spreadsheet, but of course I don't know where it is[noparse]:)[/noparse]
I have a graphing object though it's a little specialized I'll try to find time this afternoon to dig it up and see how generalized I can make it for release. It is set up to plot/display 2 channels though the sweep is based on the system counter so is limited to 32 seconds.
Attached is a test file and "TV_Plot_obj".· It can plot 2 channels of analog data, either floating point or integer.
Here's some usage from the comments (the actual code isn't commented great, sorry):
Example usage:
Plot : "TV_Plot_obj"
Plot.start
Plot.MaxTime(20) ' Set max time in seconds, approximate value
Plot.MaxVal(100) ' Set max Y value
Plot.freshscreen ' Clean up plot area
Plot.PlotA(5.2) ' plot data - floats
Plot.PlotB(fp.ffloat(x))
Plot.UpdateText(chA,ChB) ' Updates time and values in text area using float value
Plot.PlotIntA(5) ' plot data - Integers
Plot.PlotIntB(X)
Plot.UpdateIntText(chA,ChB) ' Updates time and values in text area using integers
Time can be any value, though not very accurate, it at least gives you a rough time base.
I tried to take a picture to post, but the picture scan wasn't cooperating.
Hope it helps, it's adopted from a research project I was involved in, which with luck, will be presented at a NATO conference this year!· This was also my 1st attempt working with graphics video.... crash course for the project [noparse]:)[/noparse]
Rich
-Martin
StampPlot - GUI and Plotting, and XBee Wireless Adapters
Southern Illinois University Carbondale, Electronic Systems Technologies
And you didn't have to be very patient, either.
Rich
-Martin
Paul Baker
