expanding memmory to 5gb
hey guys..
·· ok so ive awalys wanted to be able to controll a hard drive with a chip. the propeller has enough i\o's and i believe it is fast enough. the first project im planning on using this for is an mp3 player for my car. I was just wondering if anyone has done this yet? if so, what are some good resources for hard drive pinouts and protocall?·i know this has been done with the amtel but i havnt found any really clear resources. if i do figure this out id be more than happy to create an object for it. i think even for a robot it could be usefull.
ok ill go into a little detail of what it is i want to do.
i want to make an mp3 player compact enough to fit into the dash board
the propeller will manage the mp3 data and send it to an sta chip
a wi-fi wireless module will be included so i can 'click and drag' songs from my house to my car
this is a long term project but my first step is interfacing with more than 5 gigs of memmory. any links on hard drive technical data would help out a lot!
or the SD route, we already have drivers for that, although they only handle root directory files at the moment. and no file seek.
Here is a ATA harddrive pinout http://www.technick.net/public/code/cp_dpage.php?aiocp_dp=pinconhdd_ata_int
Here is a IDE·harddrive pinout http://www.technick.net/public/code/cp_dpage.php?aiocp_dp=pinconhdd_ide_int
Here is·the·compactflash pinout http://www.technick.net/public/code/cp_dpage.php?aiocp_dp=pinconbus_compact_flash
My computer, http://forums.parallax.com/showthread.php?p=630466
ok talking about this is making me feel ovwewhelmed lol.. okokok one step at a time.
as for a fat table.. i think im going to make up my own system of keeping data in order.. this way i can keep it simple. i should be able to throw data on the drive however i want right? as long as i can keep track of where it is right?
Note however·that many new high capacity disks are Serial ATA which is a completely different interface.
If all you are wanting to do is interface a hdd to a propeller to play back music I would recommend a USB drive and the following product.
www.vinculum.com/prd_vmusic1.html
http://www.ghielectronics.com/products.php
I was originally going to recommend he look at the USBwiz however upon searching for the USBwiz I found the VMusic.
Thank you for your friends opinion, will take that into consideration if I ever need to add usb to a project.
ThePenguinMaster
I like your idea of wi-fi transfer. That really makes the idea cool.
Post Edited (computer guy) : 5/26/2007 2:19:49 AM GMT
the wifi transfer is actually the only practical way i can see of getting the music to the hard drive without having to constantally pull the drive and putting it back in.. that would just suck. i know i could use an sd card but for majopr transfers og 10gb or more it could e a lot of running back and forth. the wifi transfer shouldnt be too hard.
check out sparkfun. they have a module made for dealing with wifi.. however, it dose come with a pretty big price tag of about 100 bucks. i think it also runs java code? wow.. that could get interesting!
