Can you use the Propeller Demo Board USB port to communicate with PC ?
Bean
I've tried using simple_serial with both pin 30 and 31. But I cannot get the red LED (send) to light at all.
I'm just using
Serial: "Simple_Serial"
Serial.Start(30, 31, 9600)
REPEAT
· Serial.tx("A")
I've tried swapping 30 and 31, but I cannot get any lights on the USB port on the demo board.
What am I doing wrong ?
Bean.
“The United States is a nation of laws -· poorly written and randomly enforced.” - Frank Zappa
www.hittconsulting.com
I'm just using
REPEAT
· Serial.tx("A")
Bean.
Have you tried using the Full Duplex object? I have seen a few people having issues with the Simple Serial Object. Just a suggestion to narrow things down. Take care.
Chris Savage
Parallax Tech Support
The pin numbers do need to be swapped ("Serial.Start(31,30,9600)").
I've used FullDuplexSerial this way before (in BoeBotBasic). I'm not sure
if I've tried Simple_Serial though. It should work the same.
I think I got it working now, thanks.
Bean.
Post Edited (Bean (Hitt Consulting)) : 5/24/2007 6:48:52 PM GMT
Paul Baker
Working perfectly now using the PLX-DAQ software.
Thanks to everyone for your help.
Bean
