Odd power supply question
Damien Allen
I was wondering if anybody knows a way of obtaining a DC supply from the phase conductor ONLY of an AC supply? or obtaining dual rails from just the positive conductor of a DC supply?
It would be extremely useful if it is possible.
I assume you mean without access to ground or neutral?
On the AC side, you might be able to do what you want with a current transformer, BUT the current in the phase conductor must be present at all times. As well, there are some technical risks associated with current transformer work. Learn before experimenting!
The DC effort may be as simple as using a negative voltage chopper circuit.
What is it, exactly, you're trying to do?
Tom Sisk
http://www.siskconsult.com
I hope that sounds clear. If not i'll draw a pic to illustrate what i'm trying to achieve
Another possibility is a 1-Wire like setup (look at Maxim/Dallas' website). These multiplex power and a signal along a single conductor (with a ground wire for reference) and there are some temperature sensors included in the device series. The devices are addressable and are commonly used in building control systems where ambient temperature sensing at multiple specific sites is needed with minimal wiring.
Here's one example of a 1-wire temperature sensor rated from -55C to 100C with an accuracy of 0.5C (from -10C to 85C): www.maxim-ic.com/quick_view2.cfm/qv_pk/2816.
The 1-Wire bus is tolerant of short circuits. If the bus is shorted, it just stops working until the short goes away long enough for the necessary command sequences to be passed around.
Post Edited (Mike Green) : 5/22/2007 5:50:56 PM GMT
Please give me your thoughts and thanks for the replies so far...
Damo
As with any kind of battery operated equipment, reducing power requirements is essential with the controller waking up only long enough to send a reading, then sleeping again until another measurement is needed. The peripherals also need to be power switched.
Post Edited (Mike Green) : 5/22/2007 8:33:49 PM GMT
I think Mike has summarized your options. Inductive may be the way to go, but may be expensive if many moulds have to be measured.
I take it the temperature is monitored to keep the curing process under control. Have you tried an infrared gun-type thermometer? If the outside temp of the mould is a useful measurement, you could have the infrared unit mounted on a swivel and servo controlled to swing from one mould to the other. Many can give accurate readings from 100' away.
Always nice to take a stab at a real-world problem!
Cheers,
Tom Sisk
Currently there is a really crude method in use where simple compensating cable is run in conduit and sprouts out just roughly where we require the measurement and is strewn across the mould. As moulds are moved about during the de-moulding process these extension cables are frequently destroyed. Repairing these 'probes' occupies an unbelievely large amount of the maintenance teams time. Also we get through about 200 metres of compensating cable a week. We have tried various methods of protecting the cable but it is not very practical considering our process.
Are there any other 'remote' power source options i could consider??
I'm off to investigate.
BTW thanks Tom and Mike for your input. Alas i have many of these real world problems to solve...wait for my next one!
Damo
So, are the probes left in the concrete or are they on the mould surface? What I'm getting at is, if a good remote power source were found, would all the probes, etc be re-usable without a lot of repair? Are the electronics on the mould box reasonably well protected?
One of Mike's suggestions reminded me of the "space elevator" project where teams build an "ascender" which climbs a metal tape, eventually to near space. One of the power sources is a set of photovoltaics on the moving ascender and the power source is a bright spotlight on the ground.
In your case, if the electronics were well protected and the control box had some photovoltaic cells on it (maybe embedded in clear resin or silicone), you could energize the system with a bright light from several feet away. That way, you could continue to power the electronics after hours and preserve the data.
Thermocouples could, in theory, be used for power (there are several fans systems for wood stoves which work on that principle from the heat given off by the stove) but they would certainly have to be in close contact with the concrete.
Maybe little wind turbines on each mould powered by a big honking fan?
Keep at it!
Cheers
Tom Sisk
The factory is quite rough and ready and whatever the solution may be, it has to be virtually indestructable.
I've attached a drawing of a mould and a very poor (sorry) picture of the factory.
Edit: Nothing can be place on the top of or side of the moulds. The electronics are contained within the chassis of the mould. We have mobile plant and equipment that move over the moulds. The probe embedded within the mould as depicted is totally re-useable. I've done some simple trials and i've had no problems.
Post Edited (Damien Allen) : 5/23/2007 8:18:21 PM GMT
This is not a sig. This is a duck. Quack.
Time and reliability are the major factors not cost
Post Edited (Damien Allen) : 5/23/2007 8:27:17 PM GMT
Cheers,
Damo
You have a series of fixed coils stationed along the track that are energized when a mold come past..
When each mold goes past a data reading station, the coil on the mold passes in close proximity to the fixed coil...
The resulting energy induced to the mold coil is then stored, and used to transmit data.
Bob
running power is difficult down the lines is difficult also the moulds might only move 2-3 metres in either direction whilst being demoulded before being set up for cast again.
Damo
1) Try to reduce the power consumption, both peak and average.
2) If you're not already doing it, monitor the battery voltage and include that with your other readings so the central system can warn when the battery needs charging or replacement.
3) Since many types of rechargable batteries tend to have a rapid fall-off in their output voltage close to full discharge, perhaps have a backup primary battery. You could have a 12V rechargable battery pack connected through a diode and a 9V alkaline battery pack connected through a diode to the main power bus, then use a switching regulator to drop this to whatever your circuit needs. When the rechargable pack drops below 9V, the backup battery could run the unit for hours to days with some kind of obvious alarm going off periodically.
that transmits meter data when the device recieves rf energy.
It is accessable using mobile, and hand held instruments..
The same technology should be adaptable to your needs...
It is the same technology used in rf tags...
The thermocouple system uses a whole bunch of t/c's in series to get up to few volts. Once there, its easy enough to step up the voltage to run the electronics.
The woodstove fan I told you about runs a 6" diameter fan. The t/c block is about the size of a deck of cards and has fins on it. In your application, the fins could be gotten rid of, I bet. At room temperature, just putting your hand on the t/c block will get the fan turning slowly.
At retail, they're about $100....but thats only a few hours of maintenance guys' time!
PM me if you want to chase this a bit further.
Cheers,
Tom Sisk
