fab at home.. anyone seen this? is it prop worthy?
Funny thing, I was thinking about building a 3d printer... using the propeller... and the next day I see this article in popular science....
Which led me to this site..... http://fabathome.org/wiki/index.php?title=Main_Page
I want to build one, albeit a larger and better one ...· To the tune of eight feet tall and wide..· My original idea was a little more flexble in that the "tool" would be interchangable allowing either depositing materials as this one does to build up a form, or a router type tool that would cut into blocks of material to form shapes.· Also, my idea included the ability to scan a 3d object first and then replicate it..
How about fabricating multilayered PCBs this way... Who knows..
The fab at home machine is just a light weight three axis gantry they have attached a syringe too, I don't quite get the hype but it is cool.
You could use prop to control it or you could use PC based hobby CNC programs like Mach3 or TurboCNC. I'd build the machine first, eight feet tall and wide would be doable for something just laying low resolution materials but as far as it having a router on the end you would have to spend some serious cash.
Graham
http://forums.parallax.com/showthread.php?p=650217
meow, i have my own topic now? (sorta)
have you seen reprap? http://reprap.org/bin/view/Main/WebHome
Probably you should go smaller be happy to glue sections together to make larger plugs.
One of the best machines I have seen on the net uses lots of carbon tubing to form its structure, low inertia means either higher speeds or smaller motors so look into low weight yet stiff structures so you don't have to go to massive AC servos and the like.
If I was to go crazy I consider building a roof mounted triaglide:
www.indoor.flyer.co.uk/kinematics.htm
see the first image, its a parallel kinematic machine, you need a lot of rail for a given working volume but the structure is just some rods, the inertia is tiny and all the motors work together. Control is possible via Mach3 (read my document) and certainly by the propeller as the mathematics if done as I did it using Pythagoras only is simple. Another issue is the depth of cut possible because of potential for the arms to catch the work but if you build up larger models in layers it could still work well and it is possibly to get very long ball nosed cutters for this sort of thing.
Just a thought, don't wish to pervert you too far [noparse]:)[/noparse]
Graham
