hb25 — Parallax Forums
hb25
SawmillerSawmiller Posts: 276
edited 2007-05-18 12:07 in General Discussion
ok folks, i'm tired of beating my head agaisnt a wall...
im tring to move a motor using a HB25· controller.
i have the hb25 hooked up to a 7.5 v wall wart green light there
its hooked up to a small motor that i tested against the input to the hb25
fuse is good
running a sx tech board with a 2 wires coming over to the servo connections on the hb25
one is on vss
other is RA.3
heres the code
' Program Description hb25 motor controller
' Device Settings
DEVICE SX28,OSC4MHZ,TURBO,STACKX,OPTIONX
FREQ 4_000_000
' IO Pins
HB25···PIN RA.3
' Constants
' Variables
cnt······ VAR Byte
temp1···· VAR Byte
counter·· VAR Byte
· PROGRAM Start
' Subroutine Declarations
' Program Code
Start:
PAUSE 5 ' Wait For HB-25 To Initialize
Main:
LOW HB25 ' Make I/O Pin Output/Low
pulsout hb25,200
pause 5000
pulsout hb25,150
·pause 1000
· GOTO Main
' Subroutine Code
' Data
is my pulsout correct ?
what am i doing wrong ?
dan
  • SawmillerSawmiller Posts: 276
    edited 2007-05-18 01:14
    never mind...
    it was in the wiring somehow...
    reconnected the hb25 and it worked..
    shrugs.
    sorry to bother ya
    dan
    cant delete the beginning post , so i thought i would send along this snippit of code ..
    uses beans HC4led and the HB25 motor controller... just playing
    dan
    ps... dont beat me jon , for all the pauses [noparse]:)[/noparse]
