Please Review; Need Help moving bytes from byte array to longs;
Please review the attached code that is not working.... I am not sure why· but I think it has to do with my mis-understanding of how to move bytes from an array to longs... TIA
The code below is supposed to parse the GPRMC sentence of the Parrallax GPS into a memory map ala Matteo. Thanks to him for all of his support thus far.....
I figured I throw this out for a little help.
Pri ParseGPRMC(PtrSentence)|i, j, idxField, delimiter, delimiter2, tmp
NMEA 0183 version 3.00 active the Mode indicator field is added
$GPRMC,hhmmss.ss,A,llll.ll,a,yyyyy.yy,a,x.x,x.x,ddmmyy,x.x,a,m*hh
Field #
1 = UTC time of fix
2 = Data status (A=Valid position, V=navigation receiver warning)
3 = Latitude of fix
4 = N or S of longitude
5 = Longitude of fix
6 = E or W of longitude
7 = Speed over ground in knots
8 = Track made good in degrees True
9 = UTC date of fix
10 = Magnetic variation degrees (Easterly var. subtracts from true course)
11 = E or W of magnetic variation
12 = Mode indicator, (A=Autonomous, D=Differential, E=Estimated, N=Data not valid)
13 = Checksum
delimiter:=","
delimiter2:="*"
i:=6 'move off of the head to the first ","
idxField:=1
objVGA.str(PtrSentence)
objVGA.out(_crlf)
repeat while i< _sentenceSize and idxField< 13
j:=0
longfill(@tmp,0,1)
repeat while byte[noparse][[/noparse]PtrSentence+i] <> delimiter and i< _sentenceSize and byte[noparse][[/noparse]PtrSentence+i] <> delimiter2
tmp.byte[noparse][[/noparse]j] := byte[noparse][[/noparse]PtrSentence+i]
j++
i++
case (idxField)
1: long[noparse][[/noparse]constant(objMem#SensorDataAddress + objMem#GprmcUtcTime)]:=tmp
2: long[noparse][[/noparse]constant(objMem#SensorDataAddress + objMem#GprmcValid)] :=tmp
3: long[noparse][[/noparse]constant(objMem#SensorDataAddress + objMem#GprmcLat)] :=tmp
4: long[noparse][[/noparse]constant(objMem#SensorDataAddress + objMem#GprmcNs)] :=tmp
5: long[noparse][[/noparse]constant(objMem#SensorDataAddress + objMem#GprmcLon)] :=tmp
6: long[noparse][[/noparse]constant(objMem#SensorDataAddress + objMem#GprmcEw)] :=tmp
7: long[noparse][[/noparse]constant(objMem#SensorDataAddress + objMem#GprmcSpeed)] :=tmp
8: long[noparse][[/noparse]constant(objMem#SensorDataAddress + objMem#GprmcCourse)] :=tmp
9: long[noparse][[/noparse]constant(objMem#SensorDataAddress + objMem#GprmcUtcDate)] :=tmp
10: long[noparse][[/noparse]constant(objMem#SensorDataAddress + objMem#GprmcVariation)] :=tmp
11: long[noparse][[/noparse]constant(objMem#SensorDataAddress + objMem#GprmcVarEw)] :=tmp
12: long[noparse][[/noparse]constant(objMem#SensorDataAddress + objMem#GprmcMode)] :=tmp
idxField++
'bump i
i++
longfill(@tmp,0,1)
tmp.byte[noparse][[/noparse]0]:= byte[noparse][[/noparse]PtrSentence+i]
i++
tmp.byte[noparse][[/noparse]1]:=byte[noparse][[/noparse]PtrSentence+i]
tmp.byte[noparse][[/noparse]2]:=0
longMove(long[noparse][[/noparse]objMem#SensorDataAddress + objMem#GprmcCheckSum],@tmp,1)
http://forums.parallax.com/showthread.php?p=650217
meow, i have my own topic now? (sorta)
I don't know how the other part of your code looks like, but the code in the case statement looks complicated for me.
I would use the data in buffer to separate each field as strings. The format of GPS data permits this solution. The separated fields are not copied to another location of memory. Then you can convert the fields to numeric values you are interested as M. K. Borri has mentioned.
Ok, here is my preferred solution.
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 DELIM_COMMA = "," DELIM_ASTERISK = "*" GPSFIELDS = 14 _crlf = $0D _vgaPin = 16 _sentenceSize = 256 VAR long gpsData[noparse][[/noparse]GPSFIELDS] OBJ objVGA : "VGA_Text" PUB testIt | i objVGA.start(_vgaPin) objVGA.str(@TestData) objVGA.out(_crlf) ParseGPRMC(@TestData) ' ParseValues 'convert fields from string to numeric value which you are interested i := 0 objVGA.out(0) repeat while i < GPSFIELDS objVGA.dec(i) objVGA.out($20) objVGA.str(gpsData[noparse][[/noparse]i++]) objVGA.out(_crlf) repeat Pri ParseGPRMC(PtrSentence)| i, idxField, tmp {{ NMEA 0183 version 3.00 active the Mode indicator field is added $GPRMC,hhmmss.ss,A,llll.ll,a,yyyyy.yy,a,x.x,x.x,ddmmyy,x.x,a,m*hh Field # 1 = UTC time of fix 2 = Data status (A=Valid position, V=navigation receiver warning) 3 = Latitude of fix 4 = N or S of longitude 5 = Longitude of fix 6 = E or W of longitude 7 = Speed over ground in knots 8 = Track made good in degrees True 9 = UTC date of fix 10 = Magnetic variation degrees (Easterly var. subtracts from true course) 11 = E or W of magnetic variation 12 = Mode indicator, (A=Autonomous, D=Differential, E=Estimated, N=Data not valid) 13 = Checksum }} idxField := i := 0 repeat while i < _sentenceSize and idxField < GPSFIELDS - 1 gpsData[noparse][[/noparse]idxField++] := PtrSentence + i repeat while i < _sentenceSize if byte[noparse][[/noparse]PtrSentence][noparse][[/noparse] i] == 0 or byte[noparse][[/noparse]PtrSentence][noparse][[/noparse] i] == DELIM_COMMA or byte[noparse][[/noparse]PtrSentence][noparse][[/noparse] i] == DELIM_ASTERISK byte[noparse][[/noparse]PtrSentence][noparse][[/noparse] i] := 0 'terminate the field i++ quit i++ gpsData[noparse][[/noparse]idxField] := PtrSentence + i i += 2 'point after checksum byte[noparse][[/noparse]PtrSentence][noparse][[/noparse] i] := 0 'terminate the field DAT TestData byte "$GPRMC,hhmmss.ss,A,llll.ll,a,yyyyy.yy,a,x.x,x.x,ddmmyy,x.x,a,m*hh",$0D byte "Test",0Thomas
Post Edited (Kaio) : 5/17/2007 7:34:09 PM GMT
This said, Thomas' code is a lot neater than mine [noparse]:)[/noparse]
· I know my initial code was a little complex, but being new to Spin and coming from another OO language, I was trying to apply the other languages constructs... maybe they don't translate and that might be my learning cureve with SPin...
Post Edited (mre_rob) : 5/17/2007 10:42:27 AM GMT
My code should be to inspire you for a possible variant to parse the GPS data. I don't know if this code is what you need, but it can be useful to find the right way.
Thomas
