this is an easy resistor question
so something very special has· happened to me.. yep.. I got my first multi-meter. I know its a big deal when·a man picks out his first meter..
ok enough joking around. 1 megaohm
what is a megaohm? and if I have 2.1 of them how do they work in this
··········3.0v
··· I = ----
··········2.1 Mohms or megaohm's
thanks for the time..
IC layout designer
Austin Texas
··········3.0v
··· I = ----
IC layout designer
Austin Texas
I = 3.0v
···· 2,100,000 Ohms
I= 1.428uA
Post Edited (SailerMan) : 5/4/2007 1:43:20 AM GMT
a Megaohm... really? A megaOhm is 1 million Ohms
Your equation is for current (I)... Again... really? I = 3V / 2100000 Ohms = 1.428uA (micro Amps) or 1428 nA (nano Amps)
Beau Schwabe
IC Layout Engineer
I have never really done layout on a resistor that is in the MOhms before. I knew it was stupid when I pushed the submit button.. must be getting punchy... I should go home.
IC layout designer
Austin Texas
That would be a HUGE resistor in layout.
Is that your RF design on the Avatar?
Beau Schwabe
IC Layout Engineer
lol - It looks like there are two balanced coils with a third coil as a reference coil. The design actually looks familiar to me for some strange reason... When I worked at National Semiconductor, some of the Georgia Tech
students were putting together designs very similar to the one Rontopia is using as his Avatar.
Beau Schwabe
IC Layout Engineer
Im actually leaving to do some work on some in NY in a few days. I hope that will be cool as I have never been there. I will only be there 4 to 5 weeks... I can’t remember the company right now... but it’s for RF and Bi-Cmos as well.
Anyway... the question I had last night was because i had a new multi meter and I had no idea what it was saying. M to me could have stood for u or m... I just wasn’t sure. I was trying to find the resistance across a LED and I had no idea they were that resistive.
IC layout designer
Austin Texas
so do you think Im checking this in the reverse bias direction? to get 2.1 Mohms?
I have never checked an led this way, I usually just hook them up and be done with it.. but in this case I need to know the I or the current
IC layout designer
Austin Texas
You can't just "check" an LED using only a multi-meter -- they don't usually put out enough voltage for that.
you got me confused but I'm back in the game now. The good old simple silicon diode
has a voltage drop op 06 - 0.7 volts when in conducting mode.
LED are made out of other material (e.g. gallium) and the voltage drop in conducting mode is much higher.
Ed
To determine the series resistor you need for a given current just subtract that voltage from your supply and divide by the current you want to find the necessary series resistance.
I'm guessing that the 2.1MOhm you're seeing in reverse bias is a function of measurement error. Are you using an analog or digital meter?
Hope you enjoyed Cambridge, btw; I lived there for many years. Don't think I could put up with the traffic there now, though...
If your meter only uses a 1.5V battery for its resistance measurements, the LED will appear to have a nearly infinite resistance since the electrons can't jump the band gap barrier (except for the occasional one that might cheat and tunnel through the barrier or go around ... moisture, etc.).
"easy resistor question" ... Hah!
Post Edited (Mike Green) : 5/17/2007 3:41:37 AM GMT
http://www.kpsec.freeuk.com/components/led.htm
Regards
Duncan
