Intermitted problems with the IDE recognizing my BS2 and getting worse
Capt. Quirk
I have been having problems programming my BS2 off and on for sevral months. I have tested in 2 different sockets to narrow it down to the chip. When I put it back into the PDB after testing it in the other zif socket, it worked again.
I know its a connection issue, but what pin is most likely to cause the ide not to recognize the BS2. Pins 1 & 24 are the most bent and I suppose Power and Sout are the most common cause?, is it ok to put a multi-meter to pin 24 to check voltage?.
Bill
Bill
Chris Savage
Parallax Tech Support
