What is the maximun AMP and Voltage an SX can output
What is the maximum AMP and Voltage an SX can output with all pins set as output or does it not make a difference?.
Cameron
Cameron
· According to page 40, the maximum current for one pin is 45mA. With a total of 130mA for the whole device.
· The maximum voltage is 5.5volts.
Bean.
"Educate your children to self-control, to the habit of holding passion and prejudice and evil tendencies subject to an upright and reasoning will, and you have done much to abolish misery from their future and crimes from society"
Benjamin Franklin
www.hittconsulting.com
In simple words can you explain to me how to increase the AMP I can get from one SX chip pin. I have heard that you can use a transistor but I don't know how to go about this any help in this would be a great help.
Cameron.
Why not just explain what you're trying to do (in detail) so that the folks here can help you. Generic questions get generic answers, and it sounds like you have something specific in mind.
PeterM
How many amps do you need ? What are you trying to drive ?
You need to lay your cards on the table or else we just keep going back and forth playing twenty questions...
Bean.
Benjamin Franklin
There are also a wide variety of articles in the Nuts and Volts column, also downloadable using the Downloads menu item.
Does this make more sense, I am new at these things so if you need more information let me know.
Cameron
Oh and thanks to everyone for your help. This is the first time I have used a Forums and I am very impressed with the help I get thank you very much for your time.
Crydom is one common manufacturer of solid state relays. Most of these include the current limiting resistor, so you'd just connect the "+" terminal to the I/O pin and the "-" to ground or the "+" terminal to +5V and the "-" to the I/O pin. The other two terminals are the AC switch and you'd connect them in series with your motor.
Post Edited (Mike Green) : 5/14/2007 8:24:27 PM GMT
However the power circuit must be drawing more current from somewhere else all I know is that the current it needs is 500mA so I need a way to increase this, any suggestions?
Cameron
You should have no problem running your motor from this SSR.
http://www.efx-tek.com/topics/crydom.html
Bean.
Benjamin Franklin
