Leading spaces
I've seen this referred to in other posts, but no good answer.
Would it be possible to remove the 'feature' that deletes leading spaces in the posts.
This way, we could post code that is readable with indented repeat loops, etc.
It makes the code very hard to read without the indents.
Thanks for listening.
John R.
Click here to see my Nomad Build Log
I figured out how to use the CODE command. It's great and it solved my problem.
It's not well documented...
