ULN2803 on a propeller
Hi, i want to switch and dimm some led cluster.
The led cluster will use 450 mA and will run on 12V.
I want to use the Propeller and a ULN2803 Eight Darlington Array ic .
Now my question can the ULN2803 be driven in PWM by the 3.3V of the Propeller ?
And do i need a resistor from the prop to the ULN2803 inputs ?
AnubisBot
AnubisBot
i will give it a try and will post here the results.
Anubisbot
The `2803·drops a fair amount of voltage, but they're really bullet proof for interface to the outside world where ESD will destroy your best efforts.··You can·also use hefty traces at the pins to help as a heat sink.
I got my parts and had to find out that it dosent work out, 3.3V is not working.
So i will have to loock for some other parts.
Anubisbot
Are you attempting to switch a single 12V output off and on, or does this cluster have multiple parallel circuits?
The ULN2803 is for when you have multiple outputs and want to save space/part count.
If it is a single series circuit, would it kill you to use a normal transistor or mosfet?
Update: Each '2803 output is protected with its own "free-wheeling" (counter-EMF, et al.)·diode -- ideal for inductive loads.
Post Edited (PJ Allen) : 5/18/2007 12:12:10 AM GMT
Sid
Yesterday is history, tomorrow is a mystery, and today is a gift.
That is why they call it the present.
Don't have VGA?
Newzed@aol.com
Anubis BOT
Now i get it, the 2803 would work, but i have to tie the pin to 5V and then it lights up.
With the mosfet i just have it from the propeller pin to the Mosfet, i know i shoud tie the line to ground.
Anubisbot
I am doing a similar thing and came across this thread in a search.
I was also going to do just what PJ Allen suggested *not* to do.· Thank you PJ.
I have a Matrix of 8x16.· I have Shift registers(74595) to control them (1 controlling row, 2 controlling column). The 8 Row connections are Anode and the 16 column connections are cathode.
I *was* going to have a ULN2803 Darlington Array on the outputs of the 74595 connected to the 8 Anodes of the LEDs.· Apparently this won't work.
What transistor set should I have on the output of the 74595's to supply enough current for 16 LEDs? (1.5A)
Shaun
The L293D·only has 4 channels, but can supply enough current.
