javelin servos and NES
Hi All,
I am try to run two servos both are Hitec HS-475 HB. My program at the moment is simple the Nintendo NES key turn the servos.
The problem is that when a key is pressed on the NES it needs to turn one of the servo which it try to do but it doesn't continue running any code until the servo get to the correct position and it can take a long long to get there. Why is this and how can i fix this? I am trying the servo at 6v.
Many Thanks
Jonathan
ServoControl.java
NES.java
p.s. When I try to upload my java file he said that they are "* You cannot upload files that use MIME type : text/java.". How do you get round this?
Many Thanks
Jonathan
ServoControl.java
import stamp.core.PWM; import stamp.core.CPU; import stamp.peripheral.gamecontrollers.nintendo.NES; public class ServoControl { private static PWM baseServo = new PWM(CPU.pin12,173,2304); private static PWM shoulderServo = new PWM(CPU.pin13,173,2304); private static int clock = CPU.pin2; private static int strobe = CPU.pin1; private static int data = CPU.pin0; private static NES nes = new NES(data, clock, strobe); public static void main() { while (true) { System.out.print("DEBUG: "); System.out.println(nes.getButtons()); if(nes.getLeft()){ baseServo.update(220,2304); }else if(nes.getRight()){ baseServo.update(130,2304); } else{ baseServo.update(173,2304); } if(nes.getUp()){ shoulderServo.update(220,2304); }else if(nes.getDown()){ shoulderServo.update(130,2304); } else{ shoulderServo.update(173,2304); } CPU.delay(100); } } }
NES.java
package stamp.peripheral.gamecontrollers.nintendo; import stamp.core.CPU; public class NES { private int dataPin, clockPin, strobePin; private int buttonData = 255; public NES(int dataPin, int clockPin, int strobePin) { this.dataPin = dataPin; this.clockPin = clockPin; this.strobePin = strobePin; CPU.setInput(dataPin); CPU.writePin(clockPin, false); // initialize for high pulses CPU.writePin(strobePin, false); // initalize for high pulse } public int getButtons() { CPU.pulseOut(1, strobePin); // load inputs buttonData = CPU.shiftIn(dataPin, clockPin, 8, CPU.PRE_CLOCK_MSB); // return loaded data return buttonData; } public boolean getA(){ return ((buttonData & 0x80) != 0x80); } public boolean getB(){ return ((buttonData & 0x40) != 0x40); } public boolean getSelect(){ return ((buttonData & 0x20) != 0x20); } public boolean getStart(){ return ((buttonData & 0x10) != 0x10); } public boolean getUp(){ return ((buttonData & 0x08) != 0x08); } public boolean getDown(){ return ((buttonData & 0x04) != 0x04); } public boolean getLeft(){ return ((buttonData & 0x02) != 0x02); } public boolean getRight(){ return ((buttonData & 0x01) != 0x01); } }
Otherwise contact forum support.
The PWM.update() does return immediately after writing new settings.
It does not wait until the position is reached.
In your code,
······if(nes.getLeft()){
········baseServo.update(220,2304);
······}else·if(nes.getRight()){
········baseServo.update(130,2304);
······}·else{
········baseServo.update(173,2304);
if no key is pressed, the servo is moved to center position (bold).
In other words, the moment you release the key, the servo returns
to its center. I don't think that is your intention.
regards peter
That is my intention that only to be left or right while the key is held down. But the code pauses until the servo as reached the position. I can tell this because no debug info is send to the debug windows.
It works great when only 1 servo is connect just not two of them. For my Project I need 7 servo connect where 2 of them will work in parallel so that i only need 6 VP. Maybe there the circuit needs more power?
Many Thanks
Jonathan
and see if that makes a difference.
regards peter
Do I need a smoothing capacitor, If so how do i work out which value and type?
Many Thanks
Jonathan
