Is there a holder or socket for the P8X32A-M44 (QFN) style chips
Capt. Quirk
I have been looking for a socket and found none, but I have seen sockets for 8051 chips of a similar size.
If there is none, which surface mount version is the easiest to solder without using a schmartz board?
Bill
Bill
······· Come in different kinds..BUT! not cheap!·· $50.00 a sheet there abouts!Hmmm! not in latest
······ last one maybe...got to get it from car..more later,see you!
······ Cheers Dennis
http://people.delphiforums.com/cocokiwi/Image/picture.jpg
Sockets like this can be purchased as “Test Sockets” and are somewhat expensive. We have had to use them for testing SX and Propeller Chips. I’m not sure where we got ours, but try searching for “ZIF Test Sockets” and see what that gets you. Take care.
Chris Savage
Parallax Tech Support
Chris Savage
······· $45.95 a board.....=quad =25 to 8 x 4 depending!
·· Cheers Dennis
·Be nice if on could get a socket with .1 spaced pins on it ,use perf board!
Dennis
· I think this is what you want[noparse]:http:[/noparse]//www.emulation.com/cgi-cfm/insert_quantity.cfm?part_number=S-QFP-00-044-D
· http://www.emulation.com/pdf/skt108.pdf···· < PDF file of it >· 32pin Prop chip size..within $50-$60 a part
·here is the list:· http://www.emulation.com/catalog/off-the-shelf_solutions/sockets/qfp/
·· Cheers Dennis
Post Edited (cocokiwi) : 5/6/2007 6:11:07 PM GMT
··················Here,s the list [noparse]:http:[/noparse]//www.emulation.com/catalog/off-the-shelf_solutions/sockets/qfp/
·Cheers Dennis
Post Edited (cocokiwi) : 5/6/2007 6:11:52 PM GMT
Paul Baker
Post Edited (Paul Baker (Parallax)) : 5/6/2007 6:34:26 PM GMT
Put the 40 pin chip on the back of the board and mount other components on top of it.
I have a board designed that has what the proto board has and more:
1. 40 pin propeller with AT24C512
2. Prop Plug connector
3. VGA output
4. 4 servo connectors with control signal jumpers
5. 3 voltage regulators
6. 4 power bus connectors, each with gnd, 3.3, 5 and 6 (or 8.5V)
7. Reset switch
8. Servo/motor power jumper between 5V and 6V regs.
The whole board is 2.5" square.
Paul Baker
Cheers,
Simon
BTW: I type as I'm thinking, so please don't take any offense at my writing style
www.norfolkhelicopterclub.co.uk
You'll always have as many take-offs as landings, the trick is to be sure you can take-off again ;-)
In 2 of the Data Aquisition systems we have used for the model airplanes, they used the PLCC sockets. As they updated their software, they would just·change out·the chips. I wanted to use this method as I was in my next phase with my first pcb's.·I could always program the board, but I really wanted ZIF adapters for all my chips. (ZIF adapters fit my skill level or maybe just my comfort zone)
I also didn't want to solder the surface mount and there was no space savings by using a Schmartz Board. The "surface mount" socket on the 44 pin surface mount socket.pdf ,·converted a .5mm pitch to a .100" pitch w/pins for a pcb. And of course I never heared of a "Clam Shell" before this thread.·Size and weight is important.
I picked a big first project, a·semi electronic fuel injection and engine management system. It's based off a similar board by SAIC with a BS2SX,·that was intended to adjust one or two carburators for a UAV or a Giant Scale model airplane. It wasn't until I finished all the basic programing, that I discovered major design flaws with·the hardware. I still have the need for such a system, so I am building my own. I have learned a lot and I really want·it to be as profesional appearing as possible within my own skills.
Bill
BTW, what's· "IOW"
Post Edited (Capt. Quirk) : 5/9/2007 2:21:02 AM GMT
Those are interesting boards and there size appears smaller than a 2.0" x 2.0" schmartz board, I am going to look into it further and find out how easy they are to use. Thanks
Damien Allen,
You mean the PropStick-USB?. Well, hit me with a stupid stick!. That's a damm good idea.·After trying to do it the hard way, I would have wasted more than $100 just in my labor. I could use that in a 40 pin zif if I wanted too. It's·everything cramed into the least amount of space possible and it's easy. I could also use both sides of the board and save valuable·space.
Sincerely
Bill M.
Post Edited (Capt. Quirk) : 5/9/2007 5:54:52 AM GMT
