Better method of waiting on eb500 data?
I have an eb500 bluetooth module working with a bs2 (no BOE or other boards). I've connected the two together and have managed to send data from the bs2/eb500 to my bluetooth dongle on my pc and vice-versa. I'm reading the data at both ends fine.
After experimenting with the examples in the eb500 docs, I'm noticing that the presented method of waiting on data to arrive at the eb500 (from the PC/bluetooth dongle in my case) is to use something like
<simplified example>
attempt to establish a connection with SEROUT
wait for the acknowledgement with a SERIN
If the connection status pin goes low, then assume we're connected
Set the commandmode pin high to enter data mode
Sit and wait on a SERIN command until data arrives.
It's the last part that I'm having difficulty with understanding. This seems like an extremely unfriendly manner of waiting for data. Perhaps I'm just too used to event-based programming, where I'm doing thing until the "event" of data arriving calls the proper code. Is this the preferred method of receiving data from the eb500--that the code must come to a stop and wait at this command until it arrives, unable to recover if data never appears? Or is there perhaps a pin on the eb500 that activates when data arrives, and can therefor be scanned in a loop and therefore trigger/goto a SERIN at the appropriate time.....? I'm hoping I'm overlooking something.
By the way, the SERIN does have an optional timeout (look at the manual for SERIN), but the Stamp will miss the Bluetooth data if it's not actually waiting at a SERIN when the eb500 sends it.
Andy Lindsay
Education Department
DO Resume: ' If Message not rcvd, try again IF IN5 = 0 THEN Reset ' EB500 disconnected? PULSOUT 13, tLeft ' Servo control pulses PULSOUT 12, tRight SERIN 0, 84, 5, Resume, ' Get next command [noparse][[/noparse]WAITSTR buffer \ 2, buffer2, buffer3, buffer4] . . . ' Increment message index for reply. Next message from PC has to use ' reply's buf[noparse][[/noparse]1]. msgIndex = msgIndex + 1 buffer1 = msgIndex SEROUT 1, 84, [noparse][[/noparse]STR buffer \5] LOOP▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Andy Lindsay
"the Stamp will miss the Bluetooth data if it's not actually waiting at a SERIN when the eb500 sends it"
Wouldn't this be a problem if the code is doing something akin to:
ScanKeyboardForKeyPresses
DoWhateverKeyPressSuggests
SERIN 'wait small amount of time according to timeout
DoWhatever Bluetooth data suggests
Start again
....because anytime the statements other than SERIN are doing something, the data would be lost that was coming in via bluetooth? If so, how do I make sure that I never miss the incoming bluetooth data? Wouldn't Andy's BoeBot example be relying on pure chance that it is sitting in the SERIN timeout when data arrived?
Perfect world (albeit without compatible flow control) you would expect something like
if SERIN>0 then
'do bluetooth stuff
else 'no data arrived
'do nothing, continue with other code
endif
Just relying on a timeout may or may not·be unacceptable because of the amount of data you "miss" but if you can set up the PC to continually transmit at 10mS intervals and use a 20mS timeout you will increase your chances of capturing data every time.
That might still not be good enough depending on data length the timeout may have to grow to where it slows the program down too much. An alternative could be software flow control, transmit a serout[noparse][[/noparse]"get_data"] followed by a serin[noparse][[/noparse]in_data]. This exploits the fact that the PC has an event driven routine and will transmit on demand.
Whichever method you choose it is advisable to give your data a header so that the serin will always capture the complete and not a partial string.
Jeff T.
