Vincullum or DOSonChip?
I'm looking for a way to add mass storage to my Propeller project easily. I know that there have been routines to interface to an SD card directly, but I think I'd rather stick with one of these, mainly because they can take advantage of some of the more advanced features of the FAT filesystem.
I don't care what kind of storage they use. (I know Vincullum=usb stick and DOSonChip=sd card.)
Anyone have experience with either and say which they think is better?
'' Test program for Vinculum and Propeller Demo Board CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 RESET = 0 ' Vinculum /Reset SPI_CLK = 1 ' Vinculum Clock SPI_DATA = 2 ' Vinculum Data SPI_CS = 3 ' Vinculum Select EOL = 13 ' End of line (return) OBJ key : "keyboard" dsp : "tv_text" PUB start | t, s dsp.start(12) ' TV pin block for Demo Board key.start(26,27) ' Keyboard pins for Demo Board dsp.str(string("Vinculum Test Program",EOL)) outa[noparse][[/noparse]RESET]~ ' Reset device dira[noparse][[/noparse]RESET]~~ outa[noparse][[/noparse]SPI_CS]~ ' Select normally low dira[noparse][[/noparse]SPI_CS]~~ outa[noparse][[/noparse]SPI_CLK]~ ' Clock normally low dira[noparse][[/noparse]SPI_CLK]~~ dira[noparse][[/noparse]SPI_DATA]~ ' Data initially input outa[noparse][[/noparse]RESET]~~ s := 0 waitcnt(clkfreq / 4 + cnt) ' Wait for 250ms initialization repeat if s == 0 ' Buffer not full in Vinculum? s := key.key ' Look for typed character if s > 0 ' Character pending? if (transfer(false,false,s) & 1) == 0 dsp.out(s) ' If transmitted ok, echo to display s := 0 ' Allow another if ((t := transfer(true,false,0)) & 1) == 0 t := t >> 1 & $FF ' If character read from Vinculum if t & $7F => " " or t == EOL dsp.out(t) ' Display all displayable characters else dsp.out("{") ' Or display hex code of others dsp.hex(t,2) dsp.out("}") PRI transfer(read,status,data) | i, mask '' Transfer data to/from Vinculum USB Host in SPI mode data := $800 | $400 & read | $200 & status | data << 1 mask := $800 outa[noparse][[/noparse]SPI_CLK]~~ ' At least one clock prior to selecting outa[noparse][[/noparse]SPI_CLK]~ outa[noparse][[/noparse]SPI_CS]~~ ' Select chip repeat i from 1 to 12 ' Start, direction, address, 8 data, status dira[noparse][[/noparse]SPI_DATA] := i < 4 or i < 12 and not read outa[noparse][[/noparse]SPI_DATA] := (data & mask) > 0 result |= mask & (ina[noparse][[/noparse]SPI_DATA] > 0) outa[noparse][[/noparse]SPI_CLK]~~ ' Data valid on positive edge of clock dira[noparse][[/noparse]SPI_DATA]~ ' Let data line float after hold time outa[noparse][[/noparse]SPI_CLK]~ mask >>= 1 outa[noparse][[/noparse]SPI_CS]~ ' Deselect chip outa[noparse][[/noparse]SPI_CLK]~~ ' At least one clock after deselecting outa[noparse][[/noparse]SPI_CLK]~http://www.cyberguys.com/templates/searchdetail.asp?productID=9886
Jeff T.
