Mathe-problems
Re: mathe-problems
hi folks,
i working on little neural net with the propChips
as OBJ =
OBJ
text : "vga_text"
f : "FloatMath"
fp : "FloatString"
now i have problems with this equations:
=> outH1 = 1 / (1+exp(-1 * inH1));
1
this means: outH1 := __________
- inH1
1 + e
exp = 2.718281828 as constant
long inH1 = 0.009068429 as variable
my experiment:
x1 := f.FMul(-1.0,inH1)
x2 := f.FSqr(x1)
x3 := f.FMul(exp,x2)
x4 := f.FAdd(1.0,x3)
outH1 := f.FDiv(1.0,x4)
text.out($0D) ' newline
text.str(fp.FloatToString(outH1)) == 1
should be: 0.5022670917
with the calculater: (1/(1+e(-1*0.009068429))))
or can i make a function or a methode
for
- inH1
1 + e
have somebody tips or hints for this problem???
its possible to calculate this equation with the prop??
thanks for any help
regards nomad
hi folks,
as OBJ =
OBJ
text : "vga_text"
f : "FloatMath"
fp : "FloatString"
1
- inH1
1 + e
my experiment:
x2 := f.FSqr(x1)
for
- inH1
1 + e
thanks for any help
regards nomad
Not sure if I'm correct -- haven't got a PChip near me at the moment.
I think you need to recode like: outH1 = 1 / (1+CONSTANT( exp(-1 * inH1) ));
As I say, I could be wrong! But hope that helps.
Cheers,
Simon
BTW: I type as I'm thinking, so please don't take any offense at my writing style
www.norfolkhelicopterclub.co.uk
You'll always have as many take-offs as landings, the trick is to be sure you can take-off again ;-)
There is an FEXP() function for the Propeller, but you have to use the Float32 library instead of FloatMath. Download it from the Object Exchange. There's a detailed document describing the various calls and the speed of the routines.
thank you verry much
for your hints and tips
in switzerland its 18.30 PM
on monday i do some experiments with your answers
thanks
regards nomad
Thanks for your verry god hint:
the PDF-File is verry good (documentation for Float32Full)
its runing and the output is correct
Regards
nomad
The reference
Original equations
1
output: ________________ = 0.603
-0.42
1+e
with calculater:
output := (1.0 / (1.0 + e(-0.42))) = 0.6034832499
propNN2.spin
begin : Wed. 02.May 11.30:00 GMT 2007
for : Test-spin-program for equations (exp) on a propChips
- with the Demo-Board
Notes:
02.05. - interduction to test the equations of (exp)
- with f.start == starting a cog its running
- compile & run OK
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_800
xxx = pi
exp = 2.718281828
OBJ
text : "vga_text"
f : "Float32Full"
fp : "FloatString"
VAR
long testerror
long vlong
word vword
byte vbyte
long inH1 ' this is the input-value for the equations
' static = inH1 = 0.42
long outH1 ' solutions
'intermediate results
long x1, x2, x3, x4, x5, x6
PUB Main
' start Float32Full"
f.start
'start vga-term
text.start(16)
'print a string
text.str(string("PropNeuralNet Version 0.2.",13,13))
neuralNet
PUB neuralNet
inH1 := 0.42
x1 := f.FMul(-1.0,inH1) ' positive Value convert to negative Value
x2 := f.Exp(x1) ' e(-0.42)
x3 := f.FAdd(1.0,x2) ' (1.0 + x2)
x4 := f.FDiv(1.0,x3) ' (1.0 / x3)
outH1 := x4
Post Edited (nomad) : 5/2/2007 10:35:48 AM GMT
