Pin not working on BS2SX
I have a BS2SX integrated into a project of mine and it seems that one of the outputs is not working. I tried writing a program that turns the output and loops to keep it on, but no voltage shows on the pin (pin 14) no matter what I do. I have had no other problems with this stamp other than this one. Does anybody recommend a test or something to that degree that I could use to determine whether or not the pin really is bad? Also, I can't just switch to another output, as all 16 I/O's are used.
Thanks in advance,
Dan
Thanks in advance,
Dan
http://www.parallax.com/dl/docs/prod/stamps/stampscomparison.pdf
Each I/O pin will only source/sink a maximum of 30 mA and a total of 60 mA per 8 I/O pins. I don't know what you have connected to all those pins or exactly what the consequences of exceeding those limits would be, but I would bet that it's not good.
A simple "flash the LED" program and circuit should be sufficient to test the pin. If you can flash the LED on pins 13 and 15, but not on 14, I'd say 14 was dead.
Steve
And yes, all the other pins work in my project except that one (and my soldering is fine).
I might implement a two transistor design so that when pin 15 is high the LED is one color and when it's low the LED turns another color.
One more thing, this stamp was free...I won it from Parallax a couple years ago, so I'm not too bummed.
-Dan
Are you saying you’re driving a Relay directly off the pin? What was the pin that failed driving?
Chris Savage
Parallax Tech Support
Chris Savage
As far as I can tell, the pins all sink very little current, but I will post it just to be sure.
Dan
Chris Savage
-Dan
Any ideas? I have the proper voltage going to the stamp from an external regulator and the drain on each pin is nowhere near the max...
Is there any way to get a replacement? I know the stamp was free was free to start with (I won it from you guys...), but shouldn't it still work?
Thanks in advance,
Dan
