Question about VGA Graphics ASM — Parallax Forums
El PaisaEl Paisa Posts: 375
edited 2007-05-01 02:18 in Propeller 1
In the shapes, box and boxfill how I change the writing color?
The only color I got is white.
    edited 2007-04-30 18:16
    El Paisa,
    if you look at the 'color' command in the form of a BINARY number...
    gr.color(i,%RRGGBBxx_RRGGBBxx)
    ...The upper BYTE is the foreground (pixel color), while the lower BYTE is the background.
    Each RGB place holder represents two bits, resulting in a total of 4 color shades for each R, G, and B.
    Example:
    gr.color(i,%11000000_00000000) ' Bright Red on Black
    gr.color(i,%00110000_00000000) ' Bright Green on Black
    gr.color(i,%11110000_00001100) ' Bright Yellow on Blue
    Note:
    'i' represents the tile number
    Beau Schwabe
    IC Layout Engineer
  • El PaisaEl Paisa Posts: 375
    edited 2007-04-30 18:35
    Beau,
    That part understand.
    What I want is able to change color to draw like lines, shapes, etc NOT tiles.
    edited 2007-04-30 18:51
    Looking at the VGA_graphics ASM, looks like there are not way to change colors except the tile color, right?
    I would like to change writing colors to draw boxes,shapes, text, etc.
    edited 2007-04-30 20:22
    El Paisa,
    I'm not sure I understand your question. Each Tile can only support 2 colors.... a foreground color which is what you plot with lines, boxes, shapes, text, etc. and a background color.
    To draw Bright Red lines, boxes, shapes, text, etc. on a Black background...
    To draw Bright Green lines, boxes, shapes, text, etc. on a Black background...
    To draw Bright Yellow lines, boxes, shapes, text, etc. on a Blue background...
    again 'i' specifies which tile you want to configure
    gr.color(i,%rrggbbxx_rrggbbxx)
                |||||||| ||||||oo-NotUsed
                |||||||| ||||oo------Blue(00,01,10,11)--background
                |||||||| ||oo-------Green(00,01,10,11)--background
                |||||||| oo-----------Red(00,01,10,11)--background
                ||||||oo----------NotUsed
                ||||oo---------------Blue(00,01,10,11)--foreground
                ||oo----------------Green(00,01,10,11)--foreground
                oo--------------------Red(00,01,10,11)--foreground
                                           |  |  |  High Intensity
                                           |  |  Medium Intensity
                                           |  Low Intensity
                                           Off
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 4/30/2007 8:39:53 PM GMT
    edited 2007-05-01 02:10
    This does not tell me how to change the foregrouind color only the background.
    El Paisa,
    "This does not tell me how to change the foregrouind color only the background."
    Please take a closer look, it tells you how to change both foreground colors and background colors.
    Beau Schwabe
    IC Layout Engineer
