Analog-Digital Converter — Parallax Forums
mgxdbmgxdb Posts: 8
edited 2007-04-28 01:30 in BASIC Stamp
I am having trouble turning the output from an ADC0804 into the input for the BS2. I am trying to use the input·to set off LED's in that lie in a row. A Variable voltage controls the output of the ADC and I have successfully got it to light up LEDs in binary, but i need the ones on the BS2 board to light up sequentially, not the ones on the ADC proto board. Pins 8-15 on the BS2 board are outputs to the LEDs.
In short, I need to convert the binary from the ADC into a decimal value for the BS2's input.
Currently, i have it set up as follows in the picture:
Post Edited (mgxdb) : 4/23/2007 7:43:28 PM GMT
adc.JPG 23.8K
    edited 2007-04-23 20:06
    1) Can you successfully read from the ADC0804 and produce a number that reflects the voltage measured? What number range is valid?
    2) How have you connected the LEDs? Are they setup to light when the I/O pin is LOW or HIGH? What current limiting resistor value are you using?
    3) If the LEDs are set to light when the I/O pin is HIGH, you can simply set "OUTH = 0 : DIRH = $FF" to enable the outputs and leave them off (LOW).
    4) To light the LEDs based on the byte value "v", just do "OUTH = v". If the pins are in the wrong order, you can do "OUTH = v REV 8".
    5) If the LEDs are set to go on when the I/O pin is LOW, make them all off with "OUTH = $FF : DIRH = $FF", then do either
    "OUTH = !v" or "OUTH = !(v REV 8)"
  • UnsoundcodeUnsoundcode Posts: 1,532
    edited 2007-04-23 22:30
    Hi mgdxb, you have 255 possible values from the ADC and eight leds to display them with. If you intend the values be evenly spaced thats 32 between each. You have to decide then whether you want them to light at the low/mid/high range of each increment. Here's an example that illuminates each led at the mid range value of each increment in a "thermometer" style. Mess with the case values to alter the threshold.
    SELECT ADC_VALUE
    CASE· >239
    OUTH=255
    CASE· >207
    OUTH=127
    CASE· >175
    OUTH=63
    CASE· >143
    OUTH=31
    CASE· >111
    OUTH=15
    CASE· >79
    OUTH=7
    CASE· >47
    OUTH=3
    CASE· >15
    OUTH=1
    ENDSELECT
    Jeff T.
  • mgxdbmgxdb Posts: 8
    edited 2007-04-24 05:22
    Thanks for the help guys, appreciate it.
    I will do what i can for now. If i run into trouble again, i may return to the forums.
    Thanks again, and wish me luck!
    ~MGXdb
    edited 2007-04-25 18:54
    Ok, im using the Output of the ADC0804 as the INPUT for the BS2.
    Will this work for that purpose?
    How do I read the Output of the ADC with the BS2?
    edited 2007-04-25 19:11
    mgxdg -
    Yes, that should work if everything is connected properly, In general you need to use the SHIFTOUT and SHIFIN commands to control the ADC0804:
    SHIFTOUT .... 'Set appropriate chennel number
    'Start conversion, as appropriate to the device
    SHIFTIN .... 'Retrieve data from the ADC
    Check the data sheet for particulars as to what the ADC0804 requires. Check the PBASIC Reference Manual for the syntax of SHIFTIN and SHIFTOUT.
    Bruce Bates
    edited 2007-04-25 19:18
    Thanks Bruce, but i have another question
    How do i READ pin 0 - 7 as a Word??
    i need to read the output of the ADC
  • allanlane5allanlane5 Posts: 3,815
    edited 2007-04-25 19:31
    Pin 0..7 is a BYTE, not a Word.
    And I believe it's referred to as "InL", as in "input pins, the Low 8 bits"
    So:
    MyByte VAR BYTE
    MyByte = InL ' This will read all 8 pins at the same time.
    edited 2007-04-25 19:34
    mgxdg -
    My error, I apologize. I thought this was a serail device, but it's a parallel device.
    A waste of pin ports, IMHO.
    What Allan has above is much more appropriate.
    Bruce Bates
    edited 2007-04-25 19:50
    thank you so much allan!
    edited 2007-04-26 04:54
    Hey, is it possible to use INL in a command such as
    IF INL>1 THEN "Label" ?
    If not, is there a command that will perform that same function?
    edited 2007-04-27 08:26
    Alright, Scratch that, its all up and running!
    Thanks for your help and (and support i guess you could say).
    Here is a picture of the finished product.
    The LEDs light up in a "thermometer sequence" quite nicely smilewinkgrin.gif
    320 x 240 - 17K
  • KatyBriKatyBri Posts: 171
    edited 2007-04-28 01:08
    mgxdb,
    Could you post your final working code? I'de like to see what you came up with. Thanks
    Sure, Here it is.
    ' {$STAMP BS2}
    ' {$PORT COM1}
    Bits VAR Byte
    Pins VAR Byte
    Bits = INL
    FOR Pins = 8 TO 15
    Start:
    DEBUG ? INL
    IF INL > 0 AND INL < 5 THEN led
    IF INL > 5 AND INL < 20 THEN led2
    IF INL > 20 AND INL < 40 THEN led3
    IF INL > 40 AND INL < 75 THEN led4
    IF INL > 75 AND INL < 90 THEN led5
    IF INL > 90 AND INL < 126 THEN led6
    IF INL > 126 AND INL < 254 THEN led7
    IF INL = 255 THEN led8
    GOTO Start
    led:
    HIGH 8
    PAUSE 1
    FREQOUT 0, 50, 1
    LOW Pins
    GOTO Start
    led2:
    HIGH 8
    PAUSE 1
    HIGH 9
    PAUSE 1
    FREQOUT 0, 50, 1
    LOW 8
    LOW 9
    GOTO Start
    led3:
    HIGH 8
    PAUSE 1
    HIGH 9
    PAUSE 1
    HIGH 10
    PAUSE 1
    FREQOUT 0, 50, 1
    LOW 8
    LOW 9
    LOW 10
    GOTO Start
    led4:
    HIGH 8
    PAUSE 1
    HIGH 9
    PAUSE 1
    HIGH 10
    PAUSE 1
    HIGH 11
    PAUSE 1
    FREQOUT 0, 50, 1
    LOW 8
    LOW 9
    LOW 10
    LOW 11
    GOTO Start
    led5:
    HIGH 8
    PAUSE 1
    HIGH 9
    PAUSE 1
    HIGH 10
    PAUSE 1
    HIGH 11
    PAUSE 1
    HIGH 12
    PAUSE 1
    FREQOUT 0, 50, 1
    LOW 8
    LOW 9
    LOW 10
    LOW 11
    LOW 12
    GOTO Start
    led6:
    HIGH 8
    PAUSE 1
    HIGH 9
    PAUSE 1
    HIGH 10
    PAUSE 1
    HIGH 11
    PAUSE 1
    HIGH 12
    PAUSE 1
    HIGH 13
    PAUSE 1
    FREQOUT 0, 50, 1
    LOW 8
    LOW 9
    LOW 10
    LOW 11
    LOW 12
    LOW 13
    GOTO Start
    led7:
    HIGH 8
    PAUSE 1
    HIGH 9
    PAUSE 1
    HIGH 10
    PAUSE 1
    HIGH 11
    PAUSE 1
    HIGH 12
    PAUSE 1
    HIGH 13
    PAUSE 1
    HIGH 14
    PAUSE 1
    FREQOUT 0, 50, 1
    LOW 8
    LOW 9
    LOW 10
    LOW 11
    LOW 12
    LOW 13
    LOW 14
    GOTO Start
    led8:
    HIGH 8
    PAUSE 1
    HIGH 9
    PAUSE 1
    HIGH 10
    PAUSE 1
    HIGH 11
    PAUSE 1
    HIGH 12
    PAUSE 1
    HIGH 13
    PAUSE 1
    HIGH 14
    PAUSE 1
    HIGH 15
    PAUSE 1
    FREQOUT 0, 50, 1
    LOW 8
    LOW 9
    LOW 10
    LOW 11
    LOW 12
    LOW 13
    LOW 14
    LOW 15
    GOTO Start
    You could set the "LOW" commands to a variable (like i tried to do), but it wasnt working immediately, and being pressed
    for time, i didnt bother with it.
    If youre wondering why i have FREQOUT in every section is because it would cause the stamp to deliver more power to the
    LEDs, making them brighter.
    Good luck
    ~Dakota (aka mgxdb)
