Going striaght
Just new to Boe Bots and am programing to go forward, straight but I get drift 2" to the left over a ten foot run10ft.
I have tried differant surfaces just in case of non flatness. Also turned the bot around and it still drifts.
I have changes numbers up and down to slow and speed up each side but I can not get it perfect.
Question then. How accurate should I expect and can some one then point me in the right direction to what I should change
' Robotics with the Boe-Bot - Boebotforwardthreeseconds.bs2
' Make the Boebot role forward for three seconds
' {$STAMP BS2}
' {$PBASIC 2.5}
DEBUG "Program Running"
counter······· VAR················ Word
FREQOUT 4, 500, 3000
FOR counter = 1 TO 800
· PULSOUT 13, 807········· ' left
· PULSOUT 12, 637·········· ' right
· PAUSE 20
NEXT
DEBUG CR,CR,· "Finished"
END
Cheers MArk
' {$STAMP BS2}
' {$PBASIC 2.5}
· PAUSE 20
NEXT
END
Cheers MArk
- Stephen
don't expect any better results. What you need is an encoder to count (part of) wheel cycles.
Parallax sells wheels with 8 holes and an encoder .. check this out:
Search for ENCODER on www.parallax.com
good luck.
I am very new to programing and the Boe Bots. Thanks for the info and I will update to the ENCODER when I need to be perfect. For the learning curve I think I will be ok.
Thanks again.
Mark
One thing to remember when adjusting your values to get things to go straight…A servo can only go so fast. Adjusting the slow side to speed it up won’t work. You need to slow down the faster side to match the slower side. Take care.
Chris Savage
Parallax Tech Support
Mark
You might start by decreasing the "fast" side speed (pulse length) until it matches the "slow" side speed. Then, try to increase either the slow side or the fast side a bit, to see if either change makes the bot deviate from a straight line. That process, iterated, would help you find which servo can go faster, and what the max speed of the slower servo is.
If you are trying to obtain matching (max) speed for two servos --each one mounted on the bot turning in the opposite direction (cw, ccw) to move "forward" (or "backward"), make sure you are calibrating the relative speeds of the two servos by running one servo cw and the other ccw. And, also do this for both "forward" and "backward" driving of the bot --the two servos may have different behavior in their respective cw and ccw rotation.
PAR
When adding to one side no longer seems to make a difference you’ve probably reached maximum speed and need to start subtracting from the slow side (the side that you’re turning in that direction). Due to the nature of continuous rotation servos the maximum speed is reached rather quickly when ramping from 750 out toward a given direction and the curve is non-linear. Take care.
Chris Savage
Problems are the "roads" of life,
solutions are only "onramps" to the next problem
············································· "Brad Smith"
